Heater Blower Lubrication
Old Jun 27, 2007 | 04:36 AM
J Telectro's Avatar
Default Heater Blower Lubrication
Hi everybody,
The heater blower motor on my car was chirping whenever I
ran over a bump so I took it out and cleaned it. I flushed the
bearings with WD-40 and the bearings are much smoother
and quiter now. The motor shaft has a few thousands play from
end to end but no side play. The bearings don't feel badly worn.
The question is what do I use to replace the lubricant I flushed
out? Has anyone found something that lasts so that I don't have
to keep taking this thing out to re-lubricate it?
John
Old Jun 27, 2007 | 08:24 AM
Rev's Avatar
Rev
Default RE: Heater Blower Lubrication
I would use white lithium lubricant... but there may be better things than that....
Old Jun 27, 2007 | 04:40 PM
billofdurham's Avatar
I agree with Rev.
I did mine 9 months ago and it is still running perfectly.
Old Jun 29, 2007 | 05:19 AM
J Telectro's Avatar
Hi Rev and billofdurham,
Thanks for the advice. That sounds like a good solution. Nine
months is encouraging, I've had people tell me that lubrication
doesn't work- that the only solution is to replace the motor.
I'll give this a try and hopefully it will last a little longer.
Best regards, John
IFGD
Oct 31, 2014 07:02 AM
rspi
May 27, 2013 03:03 PM
90240DLGA
Sep 11, 2009 07:32 PM
smithnr
Mar 18, 2008 01:35 PM
VolvoDriver
Sep 2, 2006 03:00 AM
