heater controls- inconsistent heat temps
Old Apr 20, 2005 | 01:28 AM
Ocotillo's Avatar
Default heater controls- inconsistent heat temps
Drivers side heat is lower than pssngr side even when the temp is at same setting. Noticed that sometimes the heat will be nice and hot say at 70* and other times 70* will feel lukewarm. What should I look out for that is wearing out or are there any adjustments I can make?
THanks
Old Apr 20, 2005 | 02:07 AM
Default RE: heater controls- inconsistent heat temps
Does your car have mcc or Ecc?
Ecc is the electric system.If you have the Auto setting on the climate module then you have ECC.Also the ECC has the numbers for the temp.
One of the motors might be bad and not work all the time if you have ECC.
Old Apr 20, 2005 | 12:51 PM
Ocotillo's Avatar
Thanks Tech, I do have the ECC system and my fan seems to be working fine but what affects the temp settings? Does the fan do this or is there a thermostat of some kind that determines the temp for both the pssngr and driver side. I guess my concern is that at the same temp setting the driveres side feels cooler that the pssngr side. Does the sun sensor hav anything to do with this?
Thanks again
Old Apr 20, 2005 | 04:27 PM
Up by your grab handles on both side of the car there should be a incabin temp sensor which helps determin temp for both sides.The sensor is inside the little plastic peice that just looks like a hole in the plastic.
Old Apr 20, 2005 | 04:44 PM
Ocotillo's Avatar
Thanks I'll check on these.
Old Apr 20, 2005 | 05:21 PM
Let me know how you make out.
Old Apr 20, 2005 | 06:57 PM
Ocotillo's Avatar
Actually, how can I tell if it's bad? Is it something you just replace? Is there a way to check it?
Thanks
Old Apr 20, 2005 | 07:51 PM
When you first start the car does the lights on the climate module blink?
You can also have the dealer calibrate the motors. to make sure one isn't out of adjustment.
Old Apr 20, 2005 | 11:26 PM
Ocotillo's Avatar
No they don't blink. I read up on the diagnostics and my car isn't giving me any codes. It's suttle and I can live with it for now but it's something I'll watch and maybe figure out. It's warming up here in Washington so I'll probably be using AC more in the next few weeks. Hopefully the AC system is ok!
thanks again
Travis
Old Apr 21, 2005 | 01:49 AM
No problem anytime.
Old Apr 21, 2005 | 02:25 PM
JimKW's Avatar
What's it mean when the lights blink? Mine blink for quite a while when I first start it up, but everything works fine.
Old Apr 21, 2005 | 02:48 PM
Ocotillo's Avatar
I think it means to check your codes for a fault in the cooling and/or heating system. If you have the Haynes 850 manual it's page 3-10.
Old Apr 21, 2005 | 04:42 PM
Yes if the lights flash that means there is codes/a fault in the system.
pete8475
Jan 31, 2025 01:06 AM
VTBricked
Aug 14, 2009 08:20 PM
PGall523
May 18, 2009 07:22 PM
2000s70gltse
Apr 5, 2008 04:32 AM
kquinby
Jan 24, 2007 09:28 PM
