heater core?
Hi,
Pressure test the cooling system to locate the leak. If pressure tester is not available, let the engine idle for 15-20 minutes and look for leak. If you do not see any obvious leak, then the heater core may be shot. Also, check the firewall where the heater hoses meet the heatercore inlet & outlet, it may be leaking there in which case you only need new O-rings I believe (someone correct me if I'm wrong).
I hope this gets you started. Keep safety in mind when working on the cooling system, as it's under high-pressure & temperature.
JPN
JPN
I'd say your diagnosis of the heatercore is correct from the symptoms you're talking about. Do you notice a coolant smell anyother time? Wet carpets?
[align=left] [/align]
Everybody seems to be having problems with their heater cores lately
https://volvoforums.com/m_72935/tm.htm
Save the attachment FYR. Will delete them within the next few days so be quick!
JPN
Hi Glenn, always good to hear from you
.https://volvoforums.com/m_72935/tm.htm
JPN
ycartf
May 6, 2013 11:19 AM
