Help! Car Starts Runs Then Shuts Down
Old Dec 3, 2021 | 10:04 PM
Gizmaster_1's Avatar
Default Help! Car Starts Runs Then Shuts Down
Hi all,
I have a 95' 850 Turbo that once in a while starts, runs and then shuts down after a few seconds. Sometimes the car will run for days with no issue but lately it's happening almost every other day and it's taking longer and longer to get it started. I got two codes one for O2 Sensor and another for the MAF. the MAF code may have been because I disconnected it while the engine was running to see it it made a difference. Today I bit the bullet and spent $300 on a New MAF, and OEM Bosch one and the problem is still there. I know the O2 won't cause the car to shut down so What Else could it be? Anyone here have ideas??
​​​​​​Thanks in advance.
Old Dec 4, 2021 | 07:43 PM
My first thought is the fuel pump or fuel pump relay. Next time it fails, try jumpering the relay to see if that gets it going. Note that a failing fuel pump relay is often a warning sign that your fuel pump is drawing too much current and may be on its last legs. Sorry to hear you spend $$ on parts that don't seem to be related to the stalling - check engine codes really tell you about a condition not a cause. Example, O2 and MAF codes are saying the fuel trim is off. If your fuel pressure is too low (say from a wonky pump), that will impact fuel trim, even with a health O2 and MAF.
buzskier
Nov 14, 2016 08:08 PM
bonesaw
Nov 16, 2013 10:02 AM
hickdead
Aug 9, 2009 02:12 PM
Wanttobecool
Mar 11, 2009 07:21 PM
