HELP Compression Test question
Old Jan 20, 2006 | 12:50 AM
rp850's Avatar
Default HELP Compression Test question
What do I need to disconnect so I don't get a spark and kill myself for my compression test? The Haynes manual says to disconnect the RPM sensor and injector harnesses but I can't figure out where the RPM sensor is under the dist. cap. I can't get a good look. Is there an easier way to ensure I won't get a spark anywhere?
THANKS!!
Old Jan 20, 2006 | 02:17 AM
rp850's Avatar
Default RE: HELP Compression Test question
Figured it out.
Disconnected 101/102 fuse.
Disconnected both leads running to coil.
Disconnected wire from coil to dist. cap (to be sure)
royalslover
May 14, 2014 08:43 PM
gilber33
Aug 8, 2009 09:50 AM
qstyle
Feb 17, 2009 11:57 PM
wheelsup
Feb 13, 2009 09:58 AM
CrazyCabbie
Feb 10, 2008 08:34 PM
