help! help!
Sounds like your ac compressor has locked up. Replace compressor.
With the engine NOT RUNNING, see if you can turn the compressor by hand. It should turn with minimal effort.
Caused by just age or if any service was performed, maybe the oil was not put back in.
Easiest way to keep the compressor from coming on is to unhook the wire to the low pressure switch. Look at the passenger side firewall. See the two black tubes? The larger tube has switch screwed in vertically. Unhook the wire that is plugged into it.
