Help the new guy out with stalling (problem fixed )
Old Apr 5, 2008 | 11:54 PM
wcb's Avatar
wcb
Default Help the new guy out with stalling (problem fixed )
Hello all .[/align]I am new and this is my 1st post. I am the original owner of a 1996 850 turbo wagon with 183000 miles, the car has been good to usfor all these years and now I would like to let may daughter have it now. the wagon look like new and Ihave done a lot of the maintenancemyself and a lot of the extra stuff like the seat back cables.[/align]My problem isthe car will randomly stop running but will start right back up again. I took it to the shop and they could not fix it. I have replaced the fuel filter , relay,fuel pump,cam sensor ,speed sensor, and maf sensor. There has been NO code and the check eng light is not on. this is driving me craze and I am spending every W/E on it. Any help ? Mike[/align]
Old Apr 6, 2008 | 12:10 AM
Default RE: Help the new guy out
Did you check the injector relay and wiring by the radiator?
It is like by the fan relay but more on the drivers side.
Old Apr 6, 2008 | 12:12 AM
wcb's Avatar
wcb
No ....what should I look for ?
Old Apr 6, 2008 | 12:16 AM
The rubber insulation holding the terminals in the plug fall apart allowing the wires to become loose.
One easy way to try to test is to lean on the cover the relay is in and see if the car stalls.
Or slide the relay out and check the wires.
Old Apr 6, 2008 | 12:22 AM
wcb's Avatar
wcb
Thanks ..I will try that.
I have been reading all night back a few pages and it seems to be a problem for some cars[:@]
Old Apr 6, 2008 | 12:23 AM
Let me know what you find.
Old Apr 6, 2008 | 12:39 AM
wcb's Avatar
wcb
Right[/align]the gray relay was just floating, but the4 wirers seamed to keep the car running ,When Imovedthem.then I unplugged it and the car stalled. I guess it good.[/align]
Old Apr 6, 2008 | 07:20 AM
The relay itself might be bad since the wires are still good.
Old Apr 6, 2008 | 12:09 PM
wcb's Avatar
wcb
I will try that. I only have about a $1000 into this project now.[:@] it's will probably a $2.00 part to fixes it.[sm=drlove.gif][/align]
Old Apr 11, 2008 | 01:24 AM
wcb's Avatar
wcb
Put the new Fuel Pump Relay in a few dats ago and it seams to be working now with NO stalling.Thanks for the help[sm=thanx.gif]
volvoinct
Jun 8, 2022 03:30 PM
sghokie
Dec 14, 2010 01:18 AM
spunkymonky
Nov 18, 2008 08:50 PM
WagHag
Oct 24, 2008 06:45 AM
knight rider
Mar 29, 2005 07:33 PM
