help!!!!!!!possible comuter or control module prob.
Old Jun 29, 2011 | 01:09 AM
firefighter850's Avatar
Default help!!!!!!!possible comuter or control module prob.
ok started havin some new issues lateley if the car is warm or its hot outside it will take a while to start up it will jus crank an ma]ybr try to fire, an sometimes when it does it sputters an shuts off takes a try or two to get started after its fired up it runs great...its a 94 850 non turbo man. trans a few ppl gave me there opinions on the problem, one was the fuel pump is bad or the fuel filter is bad but the car runs, second i seen on here was the fuel pump relay, third is the control module is goin bad an forth is my computers failing let me know what you guys think before it gets worse(im fearing) let me know your idea an if you know them the part numbers to the filter,ecu,fuel pump relay an the control module
now also im assumin the control module there refering to is the engine control module or what please get back to me thanks
Old Jun 29, 2011 | 07:23 AM
Starting issues are normally related to ignition problems if you have good fuel pressure. Sounds like you are getting SHOT GUN tech support so far. The best thing to do is work towards getting the car to stage 0. When was the last time the car was tuned up? How old are the spark plug wires? Are your vacume lines in good condition? You're working with a 17 year old car, if all these things are very old you may have 3 or 4 small problems working against you.
T5wgn
Sep 6, 2013 06:55 PM
billymedic
Oct 21, 2010 10:43 AM
CincyStateFreeze
Sep 10, 2006 01:32 AM
MrD
Jan 1, 2006 05:16 PM
moonraker
Jan 2, 2005 11:23 PM
