HELP! RADIATOR PETCOCK BROKE!
Old Feb 19, 2007 | 04:05 PM
RedTurbo850's Avatar
Default HELP! RADIATOR PETCOCK BROKE!
My friend broke it trying to get it out...
Now there's a half of it stuck in there.. How can I get it out?
Old Feb 19, 2007 | 04:07 PM
Default RE: HELP! RADIATOR PETCOCK BROKE!
The part at the dealer is 8.80. So much money for a POS part.
Old Feb 19, 2007 | 05:46 PM
JPN's Avatar
JPN
Hi Jimmy,
It does happen[8D].
Here's what I did. Take out a hex (Allen) socket, find the closest size, hammer it into the petcock and use a ratchet to turn it out. If you don't have a socket-type hex, you may be able to use regular bar-type one, just hammer it into the petcock and try turning it by hand or grab it with a Vise-grip/pliers and then turn it. If you don't know what I mean, observe the bottom of the petcock carefully (where it broke), there should be a hole shaped for Allen wrench.
I bought 2 new petcocks from FCP Groton, as I could see the original/future owner breaking it.
$8.80 isn't that bad for a lesson learned. Make your friend pay for it too, as he/she broke it
When you put the new one back in, finger tight + 1/8 turn will suffice. Don't go any tighter or you'll be coming back to this thread[8D]
Good luck,
JPN
Old Feb 19, 2007 | 06:10 PM
^Well since the coolant is advertised to last 150k miles/5 years. We just put it back, and crossed our fingers and hoped it doesn't come out again.
Old Feb 19, 2007 | 10:41 PM
I assume you got it out then?
Old Feb 19, 2007 | 11:43 PM
^Yep. He used a screwdriver and unscrewed it out...Then he screwed it back in..
Old Feb 19, 2007 | 11:52 PM
JPN's Avatar
JPN
As long as the O-ring is still there, it won't leak. You can now sleep peacefully...
JPN
Old Feb 20, 2007 | 12:15 AM
I was going to suggest an easy-out!!
Old Feb 20, 2007 | 12:16 AM
^What's that?
I have no clue if the o-ring is there or not. He screwed everything back in..
Old Feb 20, 2007 | 12:27 AM
The petcock has an O-ring on it. If it is screwed back in and not leaking then it should still be there.
Old Feb 20, 2007 | 12:30 AM
^Yeah, JPN definetely stole your thunder.
Old Feb 20, 2007 | 12:32 AM
LOL no biggie!!!
jefhon
May 7, 2018 06:17 PM
RA082324
Dec 28, 2014 08:32 AM
haircuttingcow
Sep 12, 2013 10:19 PM
fixedgearhead
Aug 29, 2013 10:25 PM
mikeawd850
Nov 30, 2012 02:26 AM
