Help with testing Cam Sensor ?
Old Jul 3, 2012 | 09:18 AM
Hypnopirate's Avatar
Default Help with testing Cam Sensor ?
Hi .. New to the forum , been trolling for days .. Massive help this place is .. decided I should join lol
Anyways .. I have a no spark issue on my 95 850 non -turbo
after searching (this forum) Ive come to the conclusion that is probably the cam position sensor or the crank sensor
after reading and read .. I honestly do not have a single clue as to how to test it .. I have a volt meter but the directions Ive read from here and other sites vary in method and are not writtin very clear
So I was hoping someone could link me to maybe a video or a detailed step by step (WITH PICS) or something
thanks - Leah
Old Jul 3, 2012 | 12:41 PM
058ovlov's Avatar
http://www.volvoclub.org.uk/tech/ser...sicTesting.pdf
Old Jul 3, 2012 | 02:38 PM
Awesome .. thanks you .. I got to step 3 of the procedure (Posted below )
and it seems My volts jumped all over the place when grounding and checking terminal NO.1 of the coil .. it never went to .7-1.3 it just dropped from 11.90 volts down to 0.03 volts slowly after engaging the starter
dose this mean coil ? or keep going down the list ?
also I wasnt able to get the car to throw any codes ??
and lastly If I check resistance on just the col (via youtube video) I get 01.5 on the red+ and blue- terminals... yet I get 0.00 on positive to coil output (center pole where the main wire goes to the distributor)
Code:
BOSCH EZ129K
1) Disconnect coil wire from distributor cap. Put coil wire
next to ground and operate starter motor. If spark is present, check
distributor rotor and cap. If spark is not present, go to next step.
2) Connect voltmeter between ignition coil connector terminal
No. 15 (Red wire) and ground. Turn ignition on. If battery voltage is
not present, check voltage supply to ignition coil. If battery voltage
is present, turn ignition off and go to next step.
3) Connect voltmeter between ignition coil terminal No. 1
(Blue wire) and ground. Operate starter motor. If about .7-1.3 volts
are present, repeat test using new ignition coil. If about .7-1.3
volts are not present, turn ignition off and go to next step.
4) Disconnect engine speed sensor connector located close to
flywheel. Connect an ohmmeter between sensor terminals. If resistance
is about 200-400 ohms, go to next step and check Camshaft Position
Sensor (CMP) signal. If resistance is not about 200-400 ohms, replace
sensor.
NOTE: Engine speed sensor is also known as Vehicle Speed Sensor
(VSS) or impulse sensor.
5) Remove intake hose. Bend aside rubber sleeve on CMP
connector. Connect voltmeter between connector terminal No. 2 and
ground. See Fig. 4. Operate starter motor. If voltage reading varies
between 0-5 volts, go to step 7). If voltage reading does not vary
between 0-5 volts, go to next step.
Fig. 4: Identifying Camshaft Position Sensor (CMP) Terminals
Courtesy of Volvo Cars of North America.
6) Connect voltmeter between CMP connector terminal No. 3 and
ground. Turn ignition on. About 10 volts should be present. Turn
ignition off. Connect an ohmmeter between CMP connector terminal No. 1
and ground. Ohmmeter should show about zero ohms. If voltage supply
and ground are okay, repeat test using new CMP. If voltage supply and
ground are not okay, reconnect intake hose and go to step 9).
7) If voltage reading varied between 0-5 volts in step 5),
disconnect power stage connector at ignition coil. Bend back rubber
sleeve on connector. Check ground supply by connecting ohmmeter
between connector terminal No. 1 and ground. See Fig. 5. Ohmmeter
should indicate zero ohms. Check voltage supply by connecting
voltmeter between terminal No. 3 and ground. Turn ignition on. Battery
voltage should be present.
Fig. 5: Identifying Power Stage Connector Terminals
8) Check power stage control signal by connecting voltmeter
between terminal No. 4 and ground. Operate starter motor. Voltmeter
should indicate .7-1.3 volts. If ground, voltage and control signal
are okay, repeat test using new power stage. If ground connection and
voltage are faulty, check wiring. If control signal is not present, go
to next step and check ECU input and output signals.
9) Connect Breakout Box (981 3190) and Adapter (981 3195) to
distributor ignition ECU. See Fig. 3. Turn ignition switch to OFF
position. Distributor ignition ECU is located in right side of engine
compartment. Remove ECU cover. Disconnect distributor ignition ECU
connector. Visually inspect all terminal connector sleeves to ensure
no terminals are damaged.
10) To install breakout box, remove distributor ignition ECU.
Press adapter onto distributor ignition ECU and pull lead upward
through slot beside module. Press distributor ignition ECU, with
adapter connected, into connector in bottom of ECU box. Connect
breakout box to adapter 60-pin connector.
11) Ensure ignition is off. To check ECU input and output
signals, connect ohmmeter between breakout box terminal No. 20 and
ground, then between breakout box terminal No. 29 and ground. Ohmmeter
should indicate about zero ohms in both cases.
12) Ensure ignition is off. Connect ohmmeter between breakout
box terminals No. 20 and 2, and between breakout box terminals No. 20
and 15. Ohmmeter should indicate about zero ohms in both cases.
13) Ensure ignition is off. Connect voltmeter between
breakout box terminals No. 20 and 10. Battery voltage should be
present. Turn ignition on. Connect voltmeter between breakout box
terminals No. 20 and 30. Battery voltage should be present.
14) Check engine speed sensor signal by connecting voltmeter
between breakout box terminals No. 1 and 2. Operate starter motor.
Voltmeter should indicate 300-400 millivolts. If signal is not
present, check sensor. See Code 1-3-1 diagnosis procedures in the
G - TESTS W/CODES article. If signal is present, go to next step and
check Camshaft Position Sensor (CMP) signal.
15) Connect voltmeter between breakout box terminals No. 20
and 4. Operate starter motor. Voltage should vary between 0-5 volts.
If voltage is okay, go to next step. If voltage is not okay, connect
voltmeter between breakout box terminals No. 20 and 14. Voltmeter
should indicate about 10 volts. If voltage is present, but signal is
not present, repeat test using new CMP. If voltage is not present,
repeat test using new ECU.
16) If voltage was okay in step 15), connect voltmeter
between breakout box terminals No. 20 and 43. Operate starter motor.
Voltage should indicate about 5-7 volts. If voltage is not present,
repeat test using ECU. If voltage is present, ignition system is
operating properly.
Old Jul 3, 2012 | 06:44 PM
anyone ... ? Im really trying to get this fixed fast I have to go back to work monday :*(
Old Jul 3, 2012 | 07:15 PM
058ovlov's Avatar
Hopefully, someone will chime in. As for me. Give me a couple-few hours. I just got back home and I have to run to the grocery store, and take care of a couple of things. Don't worry, you're not abandoned. I'd give you more guidance now, but I didn't even have the time to read your entire post, to see where you are really at. Take a breath have a beer and if someone doesn't chime in, I'll talk you through it.
Old Jul 3, 2012 | 09:02 PM
Thanks a ton...
Old Jul 4, 2012 | 06:43 PM
058ovlov's Avatar
Sorry it took me so long to get back to you. I ended up going out and having drinks last night. anyway, lets see where your at. O.k. Now when turning the engine over, the volts will jump around some. However, they should remain in the 11ish range. I can't see them really falling to 0.03 while you're cranking the engine though. (Especially if they start out @ 11.90) Is it possible the probe slipped or maybe you saw the drop after the starter disengaged? If you are 100% positive, that while the starter was spinning, you were getting 0.03 volts. Than replace the coil. (But trust me. run the test again) As to the resistance, of the actual coil. Yes you should be @ 1.5 between terminals. Now as to 0.00 on + to output. Let me guess. You ran the test with your MM set to 200 ohms, right? Assuming you ran the first two tests correctly. Move on to step 4. Now I know you said you needed the car by Monday. If you are in a real pinch, I have a backup coil and Cam sensor, in my trunk, I could priority mail to you tomorrow and you'd get it by Saturday. $20 Paypal, and you send whatever one you don't need back. I'll keep an eye on this thread throughout the day, so if you run in to anymore snags, you won't have to wait long.
Old Jul 4, 2012 | 07:34 PM
058ovlov's Avatar
PM Sent
mtc28
Dec 24, 2011 08:30 AM
denver005
Apr 26, 2009 05:36 PM
erndawg
Feb 13, 2009 10:14 PM
Volvo2001
Dec 1, 2006 12:17 AM
MikeySq
Nov 4, 2006 05:35 PM
