Volvo 850 Testing ECT Sensor Wiring
Old Apr 25, 2009 | 01:21 AM
denver005's Avatar
Default Volvo 850 Testing ECT Sensor Wiring
I recently replaced the ECT sensor (from ipdusa) on my 1996, Volvo 850 Turbo. The engine warmed up sooner and ran nicer. Few days later the Engine Check Light came on. A scan test revealed ECT sensor as the source of the problem. Before I buy another one from a Volvo dealer, I would like to check the wiring of the sensor to the ECU. I have already cleaned the connector.
What is the process to do a continuity test on the sensor wiring?
R
Old Apr 25, 2009 | 09:04 AM
Did you also replace the thermostat?
If you had just bought the sensor wouldn't it be under warranty?
Old Apr 26, 2009 | 01:22 AM
denver005's Avatar
I had replaced the Tstat about 7 months ago. Yes, it has warranty on it. I replaced the sensor with one purchased from a Volvo dealer. So far so good.
R
Old Apr 26, 2009 | 06:28 AM
Glad it is good now.
Old Apr 26, 2009 | 09:28 AM
Psaboic's Avatar
Unfortunately just because a part is new doesn't mean it is trouble free. SOunds like that is what you encountered. Glad it is working well now
Old Apr 26, 2009 | 05:36 PM
denver005's Avatar
Except for removing one of the Tstat housing T40 torx bolt, replacing the ECT is relatively simple on the 850s. A tool from sear came in handy while removing the bolt.
http://www.sears.com/shc/s/p_10153_1...yword=T40+torx
R
Stan Mosler
Forum Issues
Aug 17, 2014 06:02 AM
91shelby
Feb 15, 2013 03:22 PM
cisopen
Sep 20, 2010 05:25 PM
markisboss
Apr 27, 2008 01:23 AM
