HELP!! Tracs and ABS light on in dash and not throwing code??
Old Apr 28, 2008 | 12:39 PM
DJ850R's Avatar
Default HELP!! Tracs and ABS light on in dash and not throwing code??
I have a '97 850R GLT and I am having a problem with the trac and ABS lights in the dash come on. I have a code scanner and nothing is pulling up. My check engine light is on all the time and the only code that pulls is the MAP sensor. So I am aware of that one. But I was wondering if anyone had some insight as to why these other lights would be coming on, and what is the most cost affective way to resolve it without going to a mechanic and paying with my first born!
Thanks in advance.
I have checked the other existing forums, and I am not sure if I am looking in the right place or if anyone else has seen this similar issue.
-Rob
Old Apr 28, 2008 | 01:17 PM
billofdurham's Avatar
Default RE: HELP!! Tracs and ABS light on in dash and not throwing code??
Your scanner will not pull codes for the ABS.
It is quite possible that the ABS module has developed the fault common to these units. They can be re-built.
Check these links: http://www.modulemaster.com/en/index.php
http://home.earthlink.net/~vicrocha/...S_feedback.htm
Old Apr 28, 2008 | 06:11 PM
I would say bad ABS module.
Old Apr 29, 2008 | 10:44 AM
jks2's Avatar
+1 on the ABS module. I would pull it and send it off to be rebuilt. Easy to do and not that expensive.
Old Apr 30, 2008 | 08:46 AM
Psaboic's Avatar
At the risk of sounding like a broken record. Yes, I would follow all the above advice and repair the ABS module
Old Apr 30, 2008 | 08:09 PM
m1964's Avatar
ORIGINAL: tech
I had these lights, and my mech pulled a code for ABS pump, I still went to the dealer who said "bad ABS computer", when I asked why the code is for the ABS pump, they said "computer is throwing wrong code"-long story made short: replaced pump, no more problems.
Old Apr 30, 2008 | 08:13 PM
I have only ever replaced 1 pump and about 400 ABS modules for the pump codes.
shoter_hellas
Nov 27, 2011 11:06 PM
850GLE
Sep 22, 2009 10:28 AM
paulh
Jan 30, 2008 08:22 PM
jack2403
Jan 4, 2007 08:43 PM
vwown3d
Aug 20, 2005 03:01 PM
