s70 owners with abs light or tracs light on
Old Aug 17, 2011 | 12:51 AM
shoter_hellas's Avatar
Exclamation s70 owners with abs light or tracs light on
attention all s70 owners with abs light or tracs light on. this problem is not necessarily your abs module that is bad. it could also be your wheel speed sensors or the cables. have them checked out before you go and buy an abs module!!! this will save you time and money!!!!
Old Nov 25, 2011 | 10:05 AM
barrconstruct1's Avatar
I have this problem and the speedometer is cutting off as i am driving. If I turn the key off and back on it resets the speedometer. I might last all day, but sometimes stops again in a few minutes. I spoke onlie with a mechanic and he posted that it would be a faulty ABS speed module.
Old Nov 27, 2011 | 12:21 AM
id recommend to get the car scanned first. get the codes and see whats wrong with it then go ahead from there.
Old Nov 27, 2011 | 11:06 PM
gdog's Avatar
shoter_hellas: While you're correct, the ABS light could be ON for any fault within the ABS system, the ABS modules of this vintage have a very prevalent problem with connector solder joints breaking on the ABS module main circuit board. There are many threads around here and on other volvo forums covering this issue ad nauseum. Can be fixed by DIYer quite easily too; i.e. would recommend either you rebuild it (almost free) or have it rebuilt by someone who does it professionally (about $100) rather than buying a new module from the dealer.
These broken solder joint symptoms usually manifest in the ABS light intermittently coming ON and then going OFF. I have heard they can affect speedo operation too.
Here are some relevant threads:
https://volvoforums.com/forum/volvo-.../?ref=esp-link
post #5
https://volvoforums.com/forum/volvo-...estions-58645/
Pubcha
Nov 26, 2014 08:34 PM
mulchie
Jun 12, 2012 01:24 PM
paulh
Jan 30, 2008 08:22 PM
jack2403
Jan 4, 2007 08:43 PM
vwown3d
Aug 20, 2005 03:01 PM
