!!!!! HELP !!!! volvo 850 t5 fuel cut off problem
Old Aug 15, 2009 | 06:06 PM
kioskaskdn's Avatar
Unhappy !!!!! HELP !!!! volvo 850 t5 fuel cut off problem
Hi i have a 1995 volvo 850 t5 (2.0l turbo not the 2.3 or 2.5). I have installed a MBC, 3" intercooler pipes (the original ones just keeps blowing up ), high flow air filter, dump valve. Every time then i push the throtle down hardly and keep it in 14-15psi boost, after a few seconds the engine or the ecu cuts the fuel off. Any ideas what might be wrong? It's relly frustrating i tried lowering it to lower boost levels but always the same result, it just cuts off. Help please...
Old Aug 16, 2009 | 08:33 AM
15.5 PSI is the fuel cutoff. You need to drop the boost down to about 12 or 13 PSI.
I am running 14 on my car but when it gets cold or chilly here I have to drop it more or I will hit fuel cutoff.
Old Aug 17, 2009 | 10:26 AM
fcpgroton's Avatar
Former Sponsor
+1, that is to much boost without running a tune. You also risk running lean and hurting your engine.
Old Aug 17, 2009 | 06:40 PM
If you are going to be running that much boost even with a tune it would be a really good idea to install a wide band setup to watch Air fuel ratio's.
I have one in mine I am on the rich side but waiting to get a good tune have not finished all the mods I am going to do. I want it tuned for all the mods.
Old Aug 18, 2009 | 10:43 AM
fcpgroton's Avatar
Former Sponsor
Again, +1. This is a very good idea for any turbo car with raised boost.
paulo215
Sep 12, 2011 11:39 PM
captaincurry
Jan 10, 2010 04:34 PM
rupert77
Jan 11, 2009 11:02 AM
joker834
Nov 13, 2007 08:20 PM
Riculus
Nov 17, 2005 01:30 AM
