850 turbo cut off, won't start
Old Sep 10, 2011 | 11:57 AM
paulo215's Avatar
Default 850 turbo cut off, won't start
850 Turbo was running well. A couple mornings it started a touch roughly with a bit of gray/white smoke. Then the next afternoon, took a corner and it stopped running. Will crank, but not fire. Checked and changed the fuel filter, which was fairly dirty. Filter has refilled with fuel, so I guess the fuel pump is ok. Changed the spark plugs. Can't get it to turn over. Thoughts?
Old Sep 10, 2011 | 03:21 PM
Will it crank or not? We call that a stall so you can use the last 20 stall threads as a guide. Is the timing belt broke?
Old Sep 11, 2011 | 01:58 PM
paulo215's Avatar
it will crank but not fire/start.
Old Sep 12, 2011 | 11:39 PM
gdog's Avatar
Just because the fuel filter refilled doesn't necessarily mean you have adequate pressure at the fuel rail.. Really should ck it with a fuel pressure gauge. Fuel pump could be on its last legs or...
volvoralph
Jul 19, 2016 04:19 PM
kioskaskdn
Aug 18, 2009 10:43 AM
Gonzspeed
Feb 21, 2007 10:27 PM
Riculus
Nov 17, 2005 01:30 AM
Andres
Feb 28, 2005 07:27 PM
