How do I get to my glove box hinges?
Old Oct 12, 2010 | 01:56 PM
beckmjea's Avatar
Default How do I get to my glove box hinges?
I have a '95 Volvo 850 and I'm trying to check my blower motor. However, I can't figure out how to access my glove box hinges. The Haynes manual doesn't say how to do this. Thanks.
Old Oct 12, 2010 | 09:09 PM
You need to remove the glove box insert to gain access to the hinges. But you do not need to remove them to get to the blower motor.
Old Oct 13, 2010 | 03:30 PM
Rosew6211's Avatar
Default Glove box hinges
Open the glove box. Look for the screws securing the glove box liner to the dash. You will need a No. 25 Torq screw driver or No. 25 torq bit to fit the screw heads. Once you remove all screws, about 4, then carefully jiggle the liner a little not letting it drag on the glove box lite bulb, just work it past. With a thin screw driver carefull release the glove box lid plastic support arms from the cover. Careful! After their release, put a bag tie around them to avoid their slipping up and through the slits each side of glove box. If one should fall through, you will have to spend time looking for it. Remove the 4 screws from the hinges and remove box cover. Looking through glove box opening, you should see the fan vertically mounted on the AC/HT duct. You will also need to remove the trim panel under the dash-passenger side which is secured by screws, Just look close, remove, and then slip the panel down and out. This is the plastic, sound/heat protection knee panel under the dash. Working through the glove box opening, disconnect the fan motor wiring connecxtor. Remove the cable duct from fan motor and the two wiring connectors from their support brackets. Remove the four screws holdnig the fan motor to the duct and remove the fan. Reminder: If you wish to shelf test the motor with 12 volts or wish to run it while out of the duct and on floor mat, be sure it is secured. If entergized while just laying, it could jump around and damage the squirrel cage blower. If I don't have a car lift, I jack up the passenger side with tire chaing jack or floor jack to bring up the car side for easier seeing the screws , etc. And Yes: You do need to remove the glove box liner and and cover to do this. Reinstall in reverse order.
Old Oct 13, 2010 | 03:38 PM
Rosew6211's Avatar
Ps. My: "Volvo 850 93-97(all model) Haynes Repair Manual" Chapter 3; page 3-6 gives good details on how to remove the fan motor, etc
Old Oct 14, 2010 | 07:18 AM
beckmjea's Avatar
Thanks tech and Rosew6211!
Old Oct 14, 2010 | 03:16 PM
docmot's Avatar
While you have the fan motor out, feel around for any leaf or tree debris. That is how I discovered my model had no cabin filter. FCP has a neat attachment to install a filter.
tech
Feb 2, 2014 11:52 PM
philiptory
Jan 1, 2012 08:01 AM
robert213
Apr 30, 2006 06:33 PM
tech
Feb 24, 2005 07:51 PM
ahn2u
Feb 24, 2005 07:44 PM
