How do I raise boost without replacing ECM?
I want to raise my boost to a modest 10-12 psi without spending $500.
On all my previous turbo cars I have bean able to simply add a manual boost controller(MBC) to increase boost.
But on my 1995 850t there is no boost pressure sensor.It's my understanding that the ecm calculates boost from the MAF,TPS and rpm signals.
Can I simply unplug the electronic boost contoller(leave it electrically connected)and replace it with a MBC ?
Will that set codes?
I'm sure this info is here somewhere but could not find it
thanks in advance
thanks in advance
MBC Install
Keep in mind that fuel cut is 15 PSI. Don't set it for more than 13.5 PSI to allow for boost spikes. Above 15 PSI on the 15G is out of efficiency anyways.
LPT good for 8-10 PSI. I am running 15PSI on a 13g (1999 S70 AWD) currently and yes it does pull but it is a little out of its efficiency range. I did have a 12PSI tune and it pulled harder with that then the 15PSI tune.
Also to the OP you don't have to spend $500 for a tune. Inmotion, SpeedTuning USA and Upsolute all have tunes for under $500. Like $425, $325 and $200ish. Now yes these tunes aren't the best on the market and they aren't the most researched and developed, but they do work.
I realize you have used MBC's before and a lot of people use them on their Volvo's without problem. However an ECU upgrade is the better choice for raising boost pressures. Safer and easier to do.
Still a lot more than a MBC
Right, they have tunes for less than 500, but I have heard stories about using those tunes. Mostly with the tunes not allowing the car to start, running extremely rich or lean, and poor customer service when it came to getting the tune remapped or delivered. Personally, when I'm going to buy a tune, I'll spend the 700 dollars on an IPD tune that I know is well researched and awesome customer service.
dejan_da_dude
02-24-2015 01:17 AM
