how to pinpoint oil leak problem?
Old Jan 29, 2009 | 06:25 PM
nonsense619's Avatar
Default how to pinpoint oil leak problem?
ok so i posted about this before but cannot find out how to tell if it is a valve cover leak or vent system clogged up.how would i check the vent system and valve cover gasket?(remember im a VERY beginner with cars)there is the usual smoke coming from dipstick small oil drips after driving and oil on top of engine.Thanks in advance guys
Old Jan 29, 2009 | 06:30 PM
axelm's Avatar
I had exactly the same problem and after doing the PCV service the problem disappeared completely.
Old Jan 29, 2009 | 06:32 PM
The best thing to do is clean it all up really good.
take it for a ride like maybe 1 mile and recheck. If still dry drive 2 more miles then check again. Sometimes they are hard to find. I doubt the Cam cover is leaking.
Old Jan 29, 2009 | 07:43 PM
will do..thanks guys
Old Jan 30, 2009 | 08:02 AM
Psaboic's Avatar
Most likely the PCV system needs cleaning, but some other culprits are the gasket on the oil filler cap and the wo tiny o-rings on the dipstick. IF these are bad they can cause small to medium sized oil leaks.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
