How to program keyless remote?
I lost my remote for my 96 850t, got a new one from dealership, but now service dept. wants $150 to program the new remote. Is there anyway to program the remote myself? Thanks in advance for any advice!!!
Also just today I noticed a humming sound coming from the gas tank. Does this mean the fuel pump in the tank is about to go south? Again any advice would be much appreciated!!!!!
On other makes of cars, I have gone on to use noisy fuel pumps without a problem.
If you are able to place a hand on it... If it is hot to the touch, I would replace it.
The best thing to do, is to drive car for 20 minutes and check fuel pressure.
Also, a restriction -- such as clogged fuel filter -- will cause fuel pump to make noise.
I just programmed my keyless remote by turning the ignition on and off five times, leaving it on after the fifth time and then pressing one of the buttons on the remote. You said you tried that and it did not work? Is the battery good in the remote?
Hi and sorry for jumping in. How will a 960 remote be program? Will the above 5 time procedure work?
Thanks in advance,
wegottogo
pbone33169
Oct 22, 2009 05:55 AM
keck
Aug 12, 2005 09:51 PM
960, battery, keyless, program, programing, programming, remote, remotes, replacement, reprogram, s60, s80, s90, volvo, xc90
