HVAC Blower Squeek!
Old Jan 17, 2012 | 01:54 PM
remark90's Avatar
Default HVAC Blower Squeek!
Ok Guys & Gals can someone tell me what would cause the Blower to have a slight squeek when I trun right and going straight but not when I trun left? Crazy hua???? Kent.
Old Jan 17, 2012 | 08:03 PM
Getting old. The motor has a bearing on both ends. Maybe one is worn more than the other.
Blower Motor Removal - Volvo 850
Old Jan 17, 2012 | 09:04 PM
kenm.10's Avatar
I think this is pretty common. Might did it too. I took the motor out last weekend and blew it out, and oiled the bearings as best I could. Been quiet since....but it's only been a few days. We'll see how long it lasts. There are a lot of write-ups on this if you search it.
Old Jan 17, 2012 | 09:55 PM
Bearings will make a different noise depending on how much of a load they carry, the direction the load is placed on the bearing and also the direction the bearing is spinning.
It sounds a little odd but it's not uncommon for a bearing to quiet down when loaded in one direction compared to another. When you turn left the bearing must get pushed into a "good" position and it quiets down.
You should definitely take it apart and lube it or replace it before it starts to drag and possibly pulls too many amps through the resistor and burns out the blower motor resistor.
Attached Thumbnails HVAC Blower Squeek!-heat-ac-blower-motor-new-w-cage.jpg   HVAC Blower Squeek!-heat-ac-resistor-new.jpg
Old Jan 18, 2012 | 07:40 AM
remark90's Avatar
Sounds like a fairley straight foward job, I know what my chore is for this weekend! Thanks rspi for the link, Kent.
daver80
Oct 25, 2011 10:30 PM
daver80
Jun 25, 2011 10:08 AM
GENOA86
May 31, 2011 04:45 PM
rich nc
Jun 1, 2009 08:30 AM
tn850
Dec 5, 2007 07:20 PM
