I need help to fix my problem
Old Mar 26, 2010 | 06:45 PM
gorillajin's Avatar
Default I need help to fix my problem
Hello,
I have 1996 850r with 140k miles. Stage 0 was completed.
I got a code P0715 (Input/turbine speed sensor) so I replaced the sensor, but I still get the code.
A month ago, I flushed transmission fluid, and a week later, I got CEL and transmission warning light. The code was P0715 so I replaced the sensor. When I took out the old sensor, oil was on the tip of the sensor. Is this normal? Maybe transmission fluid was overfilled?
Since replacing the sensor didn't fix the problem, what can this be?
The transmission shifts fine.
And advice would help.
Thank you.
Old Mar 26, 2010 | 09:10 PM
Maybe an issue with the wiring.
Old Mar 27, 2010 | 12:11 AM
gorillajin's Avatar
Is there anyway to check it? If the wiring is bad, how can I fix it?
Thanks.
Old Mar 27, 2010 | 09:27 AM
You will have to get a wiring diagram and check the resistance of the wiring from one end to the other.
drenman
Nov 29, 2016 07:35 AM
1995Volvo850
Jun 15, 2012 04:21 PM
snowdoggieii
May 1, 2011 02:17 PM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
