ignition control module
Old Oct 24, 2009 | 05:20 PM
s_moneh's Avatar
Default ignition control module
where is this located in a 96/97 850??
Old Oct 25, 2009 | 10:58 PM
s_moneh's Avatar
anything?
Old Oct 26, 2009 | 01:18 PM
fcpgroton's Avatar
Former Sponsor
I believe it is under the dash, but not 100% on this. What is the issue that you are having?
Old Oct 26, 2009 | 01:41 PM
s_moneh's Avatar
my cars not starting, so going through different things that would cause this to do so, checked alot so far, ignition coil, distributor cap, plugs, cam shaft sensor everything, there is a sensor on the tranny i'm supposed to look at and swap out my ignition control module(becuase i own 2, 1 works, the other doesnt so i can use stuff from the one that works becuase i know it works and slap it into the other to se wat exactly the problem is)
but cant seem to figure it out, this is all in the process were trying to start the engine before we go out and send it to our shop to have the engine swapped
McSpartan1227
Jan 15, 2020 02:04 PM
Blacksheep 1
Oct 15, 2012 12:11 AM
mikes940
Apr 23, 2010 10:08 AM
mike_01
Jul 11, 2007 07:10 PM
funnyguy44444
Jul 9, 2007 04:17 PM
