Ignition switch
Old Jun 16, 2009 | 07:20 PM
blackbrick's Avatar
Default Ignition switch
Got this problem for a year now. Sometimes when start, had to move back key to get shifter out of park, or no lights on dash or belt warning lights and after wiggling key they would work, same with speedometer.ABS stays on at times.
Ignition switch, right?
Anyway I'm installing new one tomorrow.
Old Jun 16, 2009 | 07:52 PM
850tony's Avatar
yes it is the ing switch. do you know how? or do u need/want instructions.
Old Jun 16, 2009 | 08:19 PM
blackbrick's Avatar
Seem to be easy job to do. Thanks for quick response. I'll report tomorrow after install.
Old Jun 16, 2009 | 09:25 PM
850tony's Avatar
sounds good.
Old Jun 17, 2009 | 09:05 PM
blackbrick's Avatar
Easy 15 minute (one beer) job . Test drove it and everything is back to normal except speedometer. Sometimes works sometimes it doesn't, any ideas?
Attached Thumbnails Ignition switch-dsc01630.jpg   Ignition switch-dsc01634.jpg   Ignition switch-1.jpg   Ignition switch-2.jpg   Ignition switch-3.jpg
Old Jun 17, 2009 | 10:07 PM
850tony's Avatar
sounds like a speed sensor or a bad gauge cluster. im prolly leaning toward the gauge cluster....
Old Jun 18, 2009 | 10:10 AM
bestharry's Avatar
If your ABS also lights up intermittently, then its prolly your ABS module going bad.
Old Jun 18, 2009 | 07:02 PM
blackbrick's Avatar
Thanks guys, I was thinking in that direction. Only thing that confuses me is that with old switch, by wiggling key, I could get speedo to work. Now i have to restart car couple times to get it work.
Going nuts here, without speedo cant check average gas millage and cruise control wont work.
Old Jun 18, 2009 | 07:31 PM
850tony's Avatar
if wiggling the key before hand made it work.... are you sure that its not a bad connection on your part then you put the connector back on the ignition? (possibility maybe).
Old Jun 19, 2009 | 01:26 PM
bestharry's Avatar
My guess would be that with your BAD switch, you were giving it few restarts anyways and you would think that the problem is gone after you seee the neddle moving but now with GOOD switch, you do one start and ABS doesnt register it correctly and stays like that until it is restarted(few times).
Old Jun 19, 2009 | 02:17 PM
blackbrick's Avatar
Thanks again, guys. Hope this helps other people to. I have learned so much about my car here on this forum and you've been great.
I will check if I connected connector all the way.If that doesn't help will take ABS module out and try to fix it (was acting weird before). Also I have some other issues with car and will start new treads for specific problems so this one stay on ignition switch.
Old Jul 13, 2009 | 02:19 AM
thecheckeredflag's Avatar
so im having a similar problem. when i turn on my car occasionally the abs light will stay on and i wont be able to shift it out of park with out turning the car off and turning it back on and hoping the light will go off. but im not having problems with the spedomoter or anyting else not working. do you think it could be the same problem??
Old Jul 13, 2009 | 10:19 AM
blackbrick's Avatar
Yes ,
Speedometer is separate problem due to faulty ABS module. All other problems were fixed after replacing ignition switch. And is easy to replace, if I did it anybody can.
Check this link: http://volvospeed.com/Repair/ignit_switch.php
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
