Impossible Harmonic Balancer Removal
Old Jan 22, 2012 | 03:50 PM
ahilfman's Avatar
Default Impossible Harmonic Balancer Removal
Hey Im trying to remove the harmonic balancer...
Is the center nut (30mm) reverse threaded? I have put over a hundred pounds of force on that sob, and broken tools trying to get it off. Whats the deal? Anybody have experience with that or have any tricks?
thanks, abe
Old Jan 22, 2012 | 05:02 PM
gilber33's Avatar
Pneumatic impact.
Old Jan 22, 2012 | 06:29 PM
I read somewhere that someone jacked the car up on a tool which caused it to come loose. Not 100% sure how that worked but it did it for them.
Old Jan 22, 2012 | 08:08 PM
ahilfman's Avatar
yea, tried my impact gun on it.. wouldn't budge. I just ordered a 25" 1/2 inch breaker bar with a 20" extension. I will keep trying...just no more broken tools please God!
Old Jan 22, 2012 | 09:59 PM
BigBear854R's Avatar
At the shop I am working at one of the (old timers showed me a trick) use a breaker bar with the shortest extension possible and use the starter to break the bolt loose. Might sound strange and I didnt belive it until we did a timing belt job on a honda pilot that our 1100 foot lb impact gun wouldn't break loose.
Old Feb 21, 2012 | 05:48 PM
ahilfman's Avatar
just tried it but the starter wasn't strong enough... great idea though.
Old Feb 22, 2012 | 09:52 PM
If that didn't work then you could always try some deep creep and let it soak and use some heat !! See if you know anyone with a powerful impact gun to break it loose.
Old Feb 22, 2012 | 11:59 PM
boxpin's Avatar
Its not a reverse thread. righty tighty lefty loosy
I changed mine to the ARD lightweight pulley just last week.
Old Feb 23, 2012 | 06:58 AM
Wow!!! A good motor mount. I don't think I have ever seen one actually on a car except after it was installed.
Old Feb 23, 2012 | 07:00 PM
Lifesgoodhere's Avatar
OH DEAR GOD....not this crap again.
so utterly dangerous. I have heard of people loosing there lives doing that, exactly that. please DO NOT EVER DO THAT.
use a little heat, being very careful not to melt things, or catch grease on fire. hand torch (bernzomatic) is preferred. get it hot, does not have to be red hot, but very hot and take the impact to it using the shortest extension possible.
I actually always use a short 30 MM impact (no extension) with my 900 ft-lb Snap-on gun, (BIG RED)
I run onto this problem from time to time heat always does the trick.
Old Feb 27, 2012 | 04:53 AM
058ovlov's Avatar
Old Feb 27, 2012 | 04:59 AM
058ovlov's Avatar
Old Feb 27, 2012 | 05:42 AM
it grabbed his arm pit (cheater bar) coming back around because it slipped out of his hands and tore that major vein at his arm pit there. he died 3 hours later.
it was 3 shops down the road from where I used to work.
Old Feb 27, 2012 | 08:47 AM
Originally Posted by 058ovlov
Lol. Come on man. Is it dangerous and not too smart? Yeah. Have people sustained minor injuries trying it? No doubt they have. But fatalities? Thats a stretch.
If you'd ever seen how fast that bar flies and how hard it can hit a wall if it slips you wouldn't have to ask that question. It's worse when it's the guy in the bay next to you and you didn't know it was coming !! He braced it against the frame in the wrong direction so it had a third of a turn to get some inertia.
Old Feb 27, 2012 | 10:49 AM
boxpin's Avatar
Bottom line you need a more torque to get it off. Safest is a strong impact like 'Big Red' (love the name btw). What I use is a pretty strong impact as well. Oh, now that I think of it. I had an Ingersoll Rand that I was using before and it was a pretty good impact. But, it could not get that nut off, I had to use my 'Earthquake' impact to remove it.
Old Feb 27, 2012 | 11:58 AM
My Ingersol is the deadly one. I only use it for removing things where it's coming out or it's shearing off
Old Feb 27, 2012 | 05:28 PM
  #17
boxpin's Avatar
Thats what he needs. I am confident there has just not been enough effort.
Old Feb 28, 2012 | 08:22 PM
  #18
there it is, Big Red. Mine is a handi-down, amost 15 years old. drinks tool oil like water, still kicks like new!
edit. Actually, this ain't even it. they don't make my gun anymore lol. this is its replacement I guess.
Old Feb 29, 2012 | 02:42 AM
  #19
058ovlov's Avatar
This one will do the same job if you don't have a compressor.
Old Mar 1, 2012 | 07:56 PM
  #20
ahilfman's Avatar
Wow, ok won't try the starter trick again...
My compressor is 15 gal and a 150psi max. Even if I get a beefier gun, will it be a mute point with that size compressor?
