Indicator lever replacement
Old Oct 5, 2011 | 09:43 AM
vpatrol's Avatar
Default Indicator lever replacement
Couple questions.
My indicator lever has broken off and needs replacing. So far, I've only been able to source ones without the cruise control buttons on it which is unfortunate since I have cruise control. Worst case scenario, will the non-cruise one fit on my car? I'm assuming mine would have a couple extra connections for the cruise but hopefully whatever plug/adaptor is used for both is the same.
Second part is more of a beg. If anyone is going to a junkyard and happens to see one with cruise (assuming its left side of the steering wheel state-side), would he/she be happy for me to pay them via paypal and ship it to merry old New Zealand (insert pleading voice here)?
Old Oct 5, 2011 | 05:41 PM
I looked to see what is available and I only came across them with cruise control. The bad part is even with cruise control there are two choices and you need to know if you have a male or female plug.
That or if you get one with the wrong plug cut the end off and use your old one.
1995 VOLVO 850 TURBO Turn Signal Switch
Old Oct 6, 2011 | 08:01 AM
vpatrol's Avatar
With cruise control is great! Any idea on what they wanted for it? If swapping male for female or vice versa is easy enough, I'm happy to risk it!
Old Oct 7, 2011 | 01:25 PM
Didn't you click on the link?
"1995 VOLVO 850 TURBO turn signal switch"
in my post above?
They run about 90 bucks.
Old Oct 8, 2011 | 05:58 AM
vpatrol's Avatar
didn't even notice the link. Got it now thanks. I'm guessing the wreckers would be cheaper. I may try and email some wreckers in the states before I opt for that one. The standard ones without cruise are only about $45nzd so that one is substantially more expensive. Thanks for the link however, I may end up using it if I can't source another.
1chevelle
Apr 20, 2013 07:23 AM
taylormaed
Feb 13, 2013 08:05 AM
m.olennick
May 3, 2012 03:41 PM
V70YUL
Sep 6, 2011 10:17 PM
