Info from knowledgable person
Old Sep 29, 2008 | 05:05 AM
Steveā„¢'s Avatar
Default Info from knowledgable person
Hi everyone,
Have a few questions as I am making a few mods to my T5.
1) How do I change the discs, is there an instruction guide somewhere (to save me buying a workshop manual!)
2) Is it easy to fit a rear boot spoiler as I have just bought one?
Any help would be great
Old Sep 29, 2008 | 05:47 AM
Quick Brick's Avatar
Default RE: Info from knowledgable person
Hello Steveā„¢.
Begin by breaking the wheel nuts loose. Not off just loose.
Support the car on jack stands and remove the wheel nuts. Remove the tire.
You will need to remove the caliper retaining bolts and support the caliperup and out of the way so as not to put stress on the flex line.
Youll notice a guide/retaining pin on the disc, this will need to be removed as well.
You should now be able to remove the disc/rotor.
Make sure that you use brake disc cleaner to get the paw prints off the surface of the disc/rotor.
Installation is the reverse of the above process.
Replace the pads at the same time.
Use the proper tightening and torque process so that the wheel is secured properly. After about 50km check the torque again.
If you have developed a pulsing of any kind in the pedal when braking after you have finished you may have over tightened a lug and this is why a torque wrench is important.
http://volvospeed.com/850fbrake1.php
This should help.
[sm=icon_cheers.gif]
Old Sep 29, 2008 | 08:21 AM
Psaboic's Avatar
The only thing I would add is to note if the old pads have any shims so you can assembel it back correctly, and I would also recommend using anti-squeal/squeek compound on the backs of the pads.
Old Sep 29, 2008 | 11:04 AM
Steveā„¢'s Avatar
Brilliant, very helpful thanks guys
Old Sep 29, 2008 | 04:40 PM
Im glad we could be of help [sm=smiley20.gif]
Old Sep 30, 2008 | 06:07 PM
Also the spoiler is pretty easy. Is it a OEM one?
nmt0m35
Mar 18, 2009 08:48 PM
drabina
Oct 21, 2008 12:45 PM
s14m3
Dec 13, 2007 09:38 AM
XC70XC90
Jul 20, 2007 11:01 AM
speewee21
Jan 13, 2005 01:10 AM
