Instrument Cluster Dead?!
Hello all, the other day I was driving and I noticed that my instrument cluster died. Turbo worked but everything else, odometer, spedometer, fuel gauge, tachometer, and all notification lights, dead. The only thing that stays constantly lit is the battery indicator. Help?! I have done some research and there is no fuse or relay related to the instrument cluster. Could it have fried, or maybe something came loose? Thanks
This is a common problem. Plenty of volvo owners have suffered the same instrument cluster fate. I actually contacted the NHTSA and made a complaint because a faulty instrument cluster is a safety risk. Volvo wants over $1,000.00 to repair it. I hope other people will call and complain too so this issue will be recalled and fixed for free.
Are all lites dead including cluster liting when headligths are on, turn signal, cruise control indicator, etc? If so , I woud be doubly sure the fuse related to the cluster is good. There must be one. If it involved other circuits, be sure they are working. If fuse is OK, The inst cluster has onlly one socket connector for all functions . Before removing the dash cover to access cluster, try a couple of odd ball things such as banging lightly just abiove inst cluster, were cluster connection is located to see if this might shake the connector and get a responce, even jiggle your ignition key some while driving. Removing the cluster is a bit of a job but not a mankiller.Chapter 11, section 29 of a Volvo 850 93-97 Haynes Repair Manual( Available at auto parts stores) idetaile the exact procedure. The manual has been a life saver to me when working on my 96 850.
If nothing you do works, I would get an opinion from a the service dept. of a reputable Volvo dealer. A good dealer should give it to you for no charge. I can't believe the problem is anything more than a bad connection or a fuse. I have seen parts of clusters malfunction, but never the whole thing. Just too coincidental to happen.
I would disagree. From what I understand, there is a chip that runs the whole cluster. It could be the chip has gone bad. I have the same problem and am trying to figure different possible fixes.
Have you jiggled your key?
Is your radio working?
What about the seatbelt alert ding, do you still hear it?
The reason im asking is cause it sounds like a Possible ignition switch or switch connection issue or a wiring issue...
Their are numerous chips in your board, Unless you your board is cracked I dont think the whole cluster would go out..
Plus your turbo gauge is mechanical not electrical so thats why it would still work..
Hello all,
So, seems I am in the same boat with almost every other volvo owner out there. Cluster just stopped working. Every once and a while it will spring to life again but it is usually short lived. I have found a new cluster at a scrap yard and swapped it out. Seemed to work well after I installed it but when my wife took it to work the next morning it was up to it's old tricks. I have noticed (with the cluster hanging half out) if I wiggle the connector in the back it works fine until I hit it just right and it goes out again. Does anyone know where I can get a new connector? Or even what the correct name for it would be? Thanks
Jason
Jason
I have a '95 850 turbo and I'm experiencing something similiar. The difference is that my instrument cluster works EXCEPT my turn signal indicators and the backlight for the info display! I have plans to replace my broken odometer gear and replace my cluster bulbs with new led bulbs. What would cause that?
2003 S60. While driving, the instrument lights went out and the gauges stopped functioning, but the bright light indicator and the climate control panel/radio panel still lit. The next morning, all looks good. This sounds similar to some of your experiences. Have any of you found the answer?
Thanks for the help.
Mike
Mike
actually you can easily send out your cluster to get repaired for under $200. I just did it. Go to Ebay and lookup seller euro-electric. They give you easy instructions on how to pop out your panel, mail it to them and they ship it back fixed 1 2 3. Dont do like I did and wait for years and trying everything under the sun.
There are other sellers that seem more expensive out there.
or can search.
"VOLVO INSTRUMENT CLUSTER REPAIR". If you dont want to use ebay
you can just call them. 866 281 2414.
No I dont work there i just used their service and boy I wish i knew about it earlier
or can search.
I am having the same problem with my 2003 S80. The gauges and lights went off and on several times and then quit. Over the next few days they would come back on (except the clock) intermittently but an urgent SRS notice remained along with a yellow triangle light. I went over all of the 3 fuse boxes with a couple of different mechanics and could find none related to the instrument cluster. One independent Volvo mechanic tried a reset by removing two fuses and then waiting and restarting. Nothing. Then 2 days ago the cluster started working again, except for the clock and the urgent SRS notice. The day before this happened I had the radiator replaced but we couldn't find any problem related to that. The prior week I had the front struts replaced. A couple of months ago I had the transmission rebuilt...
I would imagine your cluster is dead, or dying. It seems to be a very common problem. (Along with many others from these overpriced swedish POS's) The new one is of course outrageously overpriced as anything else to do with a Volvo. I ended up sending my original out to get rebuilt. The replacement I had bought also dyed. The rebuild has worked great ever since I got it back. It is a lot cheaper, and the service at the rebuild shop was great.
I sent it to;
Southern Electronics Inc.
730-A Research Rd
Richmond, VA 23236
Nationwide Speedometer and Instrument Cluster Repair
I would e-mail or call them first of course. 1(804)423-1100 or 1(800)446-2880 or info@SouthernElectronics.com
Hope you get it figured out.
I sent it to;
730-A Research Rd
Richmond, VA 23236
volvo5volvo
May 29, 2012 05:46 AM
msvolvos60
Oct 3, 2008 01:17 PM
