door chime wont leave/headlight/interior light issue
Old Mar 7, 2023 | 10:13 PM
outragous_young's Avatar
Default door chime wont leave/headlight/interior light issue
Hi brick fans,
today when i was getting in my 850R and going to my college night class, when i opened the car door, the courtesy did not turn on, later when i turn on the key to accessory only to turn on the dome light, that doesn't work either, and finally when i start the car i noticed the door chime wont leave, drove it for a bit, the headlight randomly cuts out along with a lit up ABS light and the dash light going out, i switched it to running light only and everything else is fine, so that only happened when i switch the headlight on. Any idea on what is happening?
Old Mar 31, 2023 | 11:59 AM
rickster9's Avatar
[QUOTE=outragous_young;522023]Hi brick fans,
today when i was getting in my 850R and going to my college night class, when i opened the car door, the courtesy did not turn on, later when i turn on the key to accessory only to turn on the dome light, that doesn't work either, and finally when i start the car i noticed the door chime wont leave, drove it for a bit, the headlight randomly cuts out along with a lit up ABS light and the dash light going out, i switched it to running light only and everything else is fine, so that only happened when i switch the headlight on. Any idea on what is happening?[/QUOTE
Run a search, it's happens alot
Bagsasch
Apr 25, 2022 11:31 AM
Moxiegurl
May 9, 2016 07:35 PM
shirley
Sep 24, 2015 12:23 PM
shadowlord
Apr 2, 2008 12:07 PM
