INTERFERENCE ENGINES
Old 04-04-2006 | 04:23 PM
KINGI5T850's Avatar
Default INTERFERENCE ENGINES
I JUST GOT A 1996 850 TURBO AT A AUCTION FOR $925 DOLLAR IT HAS 200000 MILES ON IT THE WATER PUMP WENT OUT ON IT AND THE TIMING BELT IS OFF CAN I GET SOME ADVICE DO YOU THINK I HAVE A BAD MOTOR. I KNEW THE TIMING BELT WAS BAD BUT WHEN I SAW THE CAR AND HOW CLEAN IT WAS (NO DENTS GOOD PAINT NICE WHEELS) I JUST HAD TO GET IT. THANKS TO ALAN JONHSON FOR THE WEB PAGE.
Old 04-04-2006 | 09:21 PM
robert213's Avatar
Default RE: INTERFERENCE ENGINES
Very likely that you have a few bent valves. Remember to mark and tag (maintain original order/location) cam towers/bearing caps if you decide to take things apart.
Old 04-05-2006 | 12:45 AM
Yes you will have bent valves.
The head is pretty easy to get off.
The Valves are a little expensive but if you got the car cheap then it will be worth it.
fiey24
05-27-2019 01:59 PM
pznuttz
09-05-2015 12:22 AM
Tiberius
10-11-2007 04:49 PM
suemady
09-02-2007 08:17 PM
messenger1
04-15-2007 02:54 AM
Quick Reply: INTERFERENCE ENGINES
