Just bought
#21
Boost gauge now works
under black level on the stock gauge the AM gauge sits at 0. Once you get into white on the stock gauge, the AM one kicks in as well.
I believe the highest it read was 8-9 psi.
AFR had its own harness that plugs into the back (noice!)
I just have to figure out how to do it to the o2 sensor. How many wires and which one is the signal wire (so that I know what to look for)?
yay!
Boost controller should be here Thursday. Whats the max I should set it to?
yay!
#23
#26
#27
#28
#29
#30
Is this the BOV you got? http://www.turboxs.com/uploaded_images/525.pdf
It should have the adapters with it.
#31
I found a guy that can do an aluminum weld for me with the adapters that the BOV came with.
I thought about just going with the Forge kit, but I can't justify nearly $200 just to use a pipe.
Eventually I'll buy a block off plate for it.
Friends and I have plan to start making pieces for the 850's.
Starting will be rear cross braces for the 850 Wagon's, since they seem generally unavailable.
I think I may investigate buying a block off plate and then making our own.
What other kind of parts would ya'll like to see created?
#32
I got mine used for like $35.
It looks like brand new though.
I just didn't get the washers with it, or the allen head (lol). But, I did get those two adapters that snap in to the BOV and can be welded to the upper charge pipe.
#34
You know the German's always make good stuff!!
lol
So for and update:
MBC is IN...YEAYAH!!
Still messing with tuning
Its set lower than stock right now..only hits about sixish.
I had it pegging at 16 at one point on deep runs.
Tried messing lower, but it would still kick back on hard acceleration.
Fine now, but when I tune it, its going to be awesome!
And TIPSP...you were right. My butt dyno gave me the read out of HELL YEAH!
haha
My friend whom drives an LS1 F-body doesn't believe us that the 850 breaks em loose at 45MPH
These things are freaks.
#36
#37
Okay, so all is well with my car still.
Boost is about 10 PSi right now, as I have not had time to play around with the MBC lately.
Now, my next question is: Where do I run the hose from my BOV?
Would it be to a vac line on the front tree?
I need to know soon, as I am having a friend of mine weld the adapter to the charge pipe on top of the engine tonight or tomorrow morning. I am cutting a hole in the pipe tonight.
He can weld aluminum, and the adapter and pipe are both aluminum!
Let me know.
Let me know.
#40
