Just did plugs cap rotor. Gapped plugs at .034. Too much?
Old Apr 19, 2006 | 11:34 PM
yellow95's Avatar
Default Just did plugs cap rotor. Gapped plugs at .034. Too much?
Should I close the gap some? Let me know
Gary
Old Apr 20, 2006 | 12:11 AM
wrodri54's Avatar
Default RE: Just did plugs cap rotor. Gapped plugs at .034. Too much?
You can find the right gap for your manual or from where you purchased the plugs (ie, Autozone, Advance Auto, NAPA, NOPI, etc)
They can pull it off their computers.
William
Old Apr 20, 2006 | 01:37 AM
We always set them at .30 but if you ask REG. he will tell you to go a little bigger on the gap. It will burn a little hotter and work better. .34 will be fine.
Old Apr 20, 2006 | 02:06 AM
Mass850's Avatar
Did I just do wrong then Tech?
I just today changed the plugs and wires (didn't cure the intermittent misfire), and the manual said set at .028, was I wrong to do this?
95 850 turbo (wag)
Old Apr 20, 2006 | 02:07 AM
28-30 is factory specs. You can go a little bigger if you want it is up to you.
Old Apr 20, 2006 | 03:35 AM
Mass850's Avatar
Well I'll worry about getting the problem sorted and then go back to gaps.
Thanks!!!
Old Apr 22, 2006 | 12:42 AM
code33's Avatar
Having the gap too big may cause problems under boost. The spark may get blown out.
alam
Feb 4, 2013 02:40 PM
aryanvahedi
Nov 18, 2009 08:59 PM
chef
Feb 19, 2009 07:33 AM
ExtremeODD
Feb 15, 2008 05:59 PM
bli745
Jul 31, 2006 06:59 PM
