Leak from poorly fitting aftermarket radiator - solution?
Old Aug 26, 2008 | 11:28 PM
rationull's Avatar
Default Leak from poorly fitting aftermarket radiator - solution?
Just over a year ago the radiator in my girlfriend's 1993 850 burst the passenger side tank. I ended up getting a radiator from radiator.com I think, and swapping it out without too much drama. The fitment wasn't perfect but it was workable. Also, embarrassingly, after the job I was left with a bracket that I didn't put back in, and didn't notice until it was too late. Everything seemed to be tight enough so I didn't redo it. OK so on to the question..
Recently the car's been losing a little coolant (relatively slowly). I lifted the car and found a single drip hanging off one of the little spikes on the bottom of the fan shroud that go through the radiator structure. Looking closely, I think what's happening is that the fitment is too tight, and the fan shroud is rubbing against the radiator fins while the car's running and the assembly is vibrating. I think this has worn some small tears into the radiator.
Here are a couple of pictures of the contact between the fan shroud and the radiator:
I thought about using some radiator stop leak stuff but obviously that won't solve the contact problem. Am I going to have to bite the bullet, order an OEM radiator, and change it out again? Does the OEM radiator not contact the fan shroud like this?
I don't think the missing bracket is related, but in case it is, here's a photo of it:
Can anyone identify that or (better yet) point me to some online exploded part diagrams that I might be able to use to identify it? I haven't had any luck finding any diagrams of the radiator assembly. If I have to take the radiator out again I want to make sure to put this back in correctly.
Old Aug 27, 2008 | 06:27 PM
Default RE: Leak from poorly fitting aftermarket radiator - solution?
Not sure about the bracket either. But if it is less than a year try to get it warrantied. The OEM sits like that as well.
The fins aren't going to make it leak the solid line is what leaks. I would contact them and see if they will work with you.
Old Aug 27, 2008 | 11:43 PM
rationull's Avatar
Unfortunately I think it was over a year ago.
I realize the fins won't actually make it leak but I was thinking that maybe they got bent around a bit by the shroud and tore the core a little bit. If the OEM radiator sits like that and contacts the shroud too then maybe it's not a fitment problem. Or, maybe the bracket has something to do with it but if it does, I can't feel any slack in the radiator position so I don't know. It may be a bit looser than the OEM because IIRC I wasn't able to get all four condenser mounting bolts back in b/c of misaligned bolt holes in the new radiator.
Maybe I'll go ahead and try some stop leak and see how long it holds. If it doesn't, I'll have a pressure test done when I take it in for a timing belt in a few months and maybe I'll just have to replace it again.
Thanks!
kennymcd
Dec 29, 2010 05:47 PM
Panda
Nov 10, 2008 03:36 PM
slindstrom
Dec 2, 2007 09:41 AM
pollock
Oct 18, 2006 12:40 PM
mingster
May 18, 2006 09:15 PM
