Leaking Heater Hose
Old May 16, 2011 | 05:54 PM
Junkyardspecial's Avatar
Default Leaking Heater Hose
I sprung a leak on my upper heater hose on teh portion toward the engine, I trimmed and re clamped that part but in the process I guess I may have yanked too hard on the other end (inlet in firewall) It now leaks water on the ground and will not hold coolant and it leaks into the cabin. I know this is a fairly common thing so I was wondering what parts I need and what I need to do to fix this problem, If I can bypass the heater for now that would be great I just dont know how to remove the metal ends from the firewall to do so, thanks!
Old May 16, 2011 | 06:06 PM
Carrots's Avatar
You'll need a new heater hose inlet connector. FCP's got them. To bypass the heater core, get a piece of cut- to- length heater hose from a parts store, and remove both hoses from the engine. Connect the new hose at either end. To remove hoses from the firewall, there's yellow quick- release clips you need to push in on, and the hoses will pull out.
Old May 16, 2011 | 07:03 PM
Thanks a ton, answered all my questions! BARS stop leak has it settled til the AM when I can tackle this.
Old May 16, 2011 | 11:44 PM
gdog's Avatar
Oh no, not BARs!!!
Old May 17, 2011 | 05:09 AM
Why do people think it's ok to contaminate their entire coolant system with stuff like that?
Old May 17, 2011 | 12:10 PM
Man I wouldnt know! Those people man! You know, there are ways to drain your coolant system, something you should do every time you replace a hose? This is called a band aid fix, since I use my car a lot I needed something to get me home without losing all my coolant. Oh must have been smarter to drive it with no water.I guess thats what most Volvo owners do.
thebuellster
Dec 16, 2014 04:58 PM
ycartf
May 6, 2013 11:19 AM
Edward Xuejun Wu
Sep 25, 2012 09:39 AM
BLARCHITECT
Aug 24, 2010 11:27 AM
ANN
Mar 15, 2008 11:27 AM
