Leaking Power Steering Hose
Old Dec 10, 2014 | 10:02 PM
thebuellster's Avatar
Default Leaking Power Steering Hose
While doing routine inspections, noticed there was fluid on the power steering pump and also on the hose that connects the pump to the reservoir. As far as I know, this is referred to as the return hose? I could be wrong. The hose clamp is tight, so I am assuming the hose is old and needs to be replaced. The leak is not catastrophic and the power steering works fine for the level of fluid in it, planning on topping up the fluid after fixing the leak. Just wanted to make sure that this is the right name for the hose, and was looking for recommendations on what website or store to purchase this part from. Thank you.
Old Dec 13, 2014 | 10:54 AM
modifierwong's Avatar
You can replace it with any hydraulic hose of the proper size and length. What size it is...I'm leaning towards 3/8" ID, but I'm only 99% sure. I picked it up at Autozone. When installing it, do your best not to break the reservoir! I could only get the hose on far enough to put a clamp on it, but its been fine.
While you're at it, put in an in-line magnefine filter to prolong the life of your steering components. I picked up one that had 3/8" hose barbs...which I guess confirms the sizing of the PS hose return line.
The most important thing is to not use fuel lines instead of hydraulic lines!
Old Dec 13, 2014 | 12:44 PM
they are metric hoses, so american size hoses like 3/8" are only an approximate fit.
Old Dec 16, 2014 | 04:58 PM
Thanks guys! Gonna get the hose and fluid. I'll also look into one of those filters.
x-angel
May 29, 2011 06:13 PM
mdblythe
Dec 21, 2010 08:13 PM
matt01
Mar 18, 2010 06:45 PM
tringa
Oct 13, 2008 02:57 PM
Majki
Jun 10, 2007 12:37 PM
