Leaking oil cooler lines
Old Jun 27, 2006 | 01:17 PM
ludeless's Avatar
Default Leaking oil cooler lines
I recently replaced my radiator and have noticed some oil leaking from where the oil cooler lines attach to the RH side of the rad. I did install all new seals and clamps on the lines when i replaced the rad, so i'm a bit perplexed as to how this could be leaking from this area.
Any ideas?
Old Jun 27, 2006 | 08:42 PM
Default RE: Leaking oil cooler lines
Is it leaking from the Krimp in the line?
Old Jun 27, 2006 | 09:10 PM
ludeless's Avatar
seemed to be the crimp...i could see oil residue on the lower side of the metal crimps. I'll need to check it out more closely once i notice it again to make sure it's not the hoses.
Old Jun 29, 2006 | 10:09 PM
Psaboic's Avatar
If it is leaking from the crimp, you might just replace the line. I had the same problem and replaced the line after going to several places to see if they could either re-crimp the line, or make me a new hose. The problem is the fitting on the end of the hose is very unusual and cannot be found easily or cheaply.
The hose cost me $103 [:'(] to replace, but no more oil leak. Car is a 95 Turbo with 172K on it.
Glenn
91shelby
Apr 30, 2010 03:22 PM
supernicguy
Feb 8, 2010 01:27 AM
yoyoman
Nov 30, 2009 02:31 PM
burnferris
Mar 17, 2009 08:23 PM
