Question about oil cooler lines
Old Mar 14, 2009 | 10:40 AM
burnferris's Avatar
Default Question about oil cooler lines
So my oil cooler lines are indefinitely leaking and I noticed where they connect to the block adjacent to the crank pulley that they both bolt onto some sort of boss. With the bolt that holds them both in place I am assuming that this "boss" will come off when I remove the bolt that holds the lines in place.
My question is... Is there some sort of copper washer/gasket/o-ring behind this boss to prevent leaking? There must be something and if I pull the lines off do I need to replace whatever is there? Any knowledge would be helpful, thanks.
Jon
Old Mar 14, 2009 | 09:11 PM
There is rubber o-rings and yes I would replace them.
Old Mar 17, 2009 | 09:17 AM
burnferris's Avatar
Thanks tech for the input and since they are o-rings I'll definitely replace them.
Jon
Old Mar 17, 2009 | 08:23 PM
Let us know how it goes.
91shelby
Apr 30, 2010 03:22 PM
supernicguy
Feb 8, 2010 01:27 AM
yoyoman
Nov 30, 2009 02:31 PM
ludeless
Jun 29, 2006 10:09 PM
