lift holding issues
Old Jul 7, 2009 | 05:10 AM
vpatrol's Avatar
Default lift holding issues
I just bought a 95 850 GLE wagon. It's kind of coldish here in NZ at the moment and the back lift gate drops often. I noticed there are no visible struts. What system does it use and is it easy to replace so it holds itself up? Cheers.
Old Jul 7, 2009 | 07:40 AM
850tony's Avatar
there are lift struts behind the plastic panels in the inside of the car in the roof. easy to replace. make sure u dont crack the plastic.
Old Jul 7, 2009 | 05:20 PM
vpatrol's Avatar
Thanks for that. Is there a good way to remove all the plastic so I don't break any of it. The plastic around the lift gate is currently held with tape so the previous owner clearly didn't have any luck removing that bit
Old Jul 7, 2009 | 06:26 PM
850tony's Avatar
just dont be in a rush and you should be good. i almost always crack it, but the less crack the better.
KingDahn242
Dec 10, 2011 11:48 AM
silkhope
Jul 4, 2009 12:32 AM
bidonox
Apr 8, 2009 07:38 PM
STREETFIGHTER50
Mar 18, 2009 08:46 PM
heybuddy
Apr 18, 2007 12:58 PM
