Long crank, + Black puff of smoke.
Old Mar 11, 2010 | 10:38 PM
Twill08's Avatar
Default Long crank, + Black puff of smoke.
1995 850 T.
I have to crank my car for about 3-5 seconds, When it starts I get a puff of black smoke which smells like fuel. Shaky idle for 5-10 seconds then it settles at 900Rpm.
All signs seem to point towards a leak down problem with one of the injectors. But I don't know Volvos that well as this is my first. Is there anything else I should check.
I also just did my timing belt Could my timing be off by chance? The Engine was sitting for 6 months and I still have lifter chatter after 200 miles, any suggestions?
I get a CEL for 1-2 min after start-up then it turns off not sure what it is.
Car and injectors have 148k miles, Engine has 121K. The engine came with Bosch Red injectors but I re used the old orange ones off the bad engine, Would I be able to run the red injectors?
Old Mar 12, 2010 | 02:37 PM
Twill08's Avatar
I noticed after 15 min I had no rail pressure, Pulled the rail and flipped the key to pressurize the rail and found no injector drip.
No fuel in the FPR lines, Could I have a bad check valve on the fuel pump?
Old Mar 12, 2010 | 07:43 PM
That is possible.
Did you look at the injector good for seepage?
Old Mar 13, 2010 | 12:29 AM
Twill08's Avatar
I looked for a good 3-5 min, would it have started to seep at that point?
Old Mar 13, 2010 | 05:50 AM
Yes it would have by then.
Old Mar 13, 2010 | 10:45 AM
Twill08's Avatar
I will take another look at the injectors, black smoke is a solid sign of unburnt fuel right? My cat has a hole in the side of whatever that mesh is, could this be my problem?
I will get 2 Codes on start-up they quickly turn off
One is P0245: Turbo/Sup Wastegate Solenoid A Low
Other is P1417 4-1-3 EGR temperature sensor signal Low
Old Mar 13, 2010 | 08:03 PM
That could be an issue with the running of it.
Old Mar 13, 2010 | 09:43 PM
Twill08's Avatar
I rechecked the FPR, The line was full of gas.
Should I replace this with OEM Volvo or aftermarket?
Old Mar 13, 2010 | 09:44 PM
Sounds like you found the problem!
Old Mar 14, 2010 | 01:20 AM
Twill08's Avatar
I hope so.
Old Mar 15, 2010 | 10:41 PM
Twill08's Avatar
Replaced the Fuel pressure regulator today, problem solved!
Old Mar 16, 2010 | 12:48 AM
moneypitbrick's Avatar
still having the lifter noise? subtle lifter noise is apparently a common side effect of letting an 850 sit for a while. Sometimes it doesn't resolve completely, or only resolves after some travel, only to resurface the next time it is started cold. so I was curious as to what you are experiencing.
Old Mar 16, 2010 | 01:40 AM
Twill08's Avatar
Yep I still have the lifter noise. It's not as loud but I still hear it when the hood is up.
You also have to remember that this is the only volvo I've ever been around, Loud to me may be normal.
johnpeterdavid
Sep 16, 2009 04:58 AM
Timmy1
Oct 7, 2008 08:20 PM
Johnboy
Oct 3, 2008 08:37 AM
Johnboy
Sep 30, 2008 06:45 PM
kakins
Feb 26, 2007 09:01 PM
