losing antifreeze after radiator flush
Old Nov 23, 2011 | 10:49 AM
slimflex2's Avatar
Red face losing antifreeze after radiator flush
hey guys, my antifreeze has been getting a low after l flushed my radiator.what could be the problem.hope to hear from you as soon as possible. thanks
Old Nov 23, 2011 | 10:56 AM
VTBricked's Avatar
If your cooling system is not leaking, it could be air pockets getting replaced with coolant.
Old Nov 23, 2011 | 11:06 AM
slimflex2's Avatar
yea the radiator is not leaking.what is air pockets?
Old Nov 23, 2011 | 05:14 PM
VTBricked's Avatar
When a hose is in an upside down "U", you will have air in the top of the U until coolant circulates enough times to evacuate the air.
The heater core has both supply and return on the bottom of the core - so that's one location for an air pocket.
Watch the coolant level and add as necessary. It should stop dropping once all the air pockets are gone.
Look at the exploded "larger picture" here: The 850 has the same core.
eEuroparts - Search Results
Old Nov 23, 2011 | 10:17 PM
slimflex2's Avatar
thanks man.l really appreciate you help.let me ask you. is it safe to use mobil 1 synthetic transmission fluid in my 850?
Old Nov 23, 2011 | 11:01 PM
I have heard of people using synthetic tranny fluid. Not sure if it is the Mobil 1 brand. As long as it meets the DEX III standards it should be ok. Check the transmission service thread and the Noob sticky, it has transmission service details there.
Old Nov 25, 2011 | 03:12 PM
Henry10's Avatar
It is not uncommon for clamps/connections to leak after this job. It will take a few tightening-tries until everything is buttoned up.
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
nuclearseal
Dec 10, 2012 04:00 PM
shop2
Nov 1, 2011 08:56 AM
Cris
Mar 15, 2008 09:05 AM
Glenn B
Feb 19, 2008 04:57 PM
