Miles and gallons instead of kilometers and liters
Old Aug 2, 2008 | 05:44 AM
axelm's Avatar
Default Miles and gallons instead of kilometers and liters
I live in Argentina. We use kilometers and liters. My battery died after leaving it several hours with the key in the wrong position. I jump started the car and after that I realized that the instant fuel consumption indicator was showing really crazy numbers. The more I floored the throttle, the lower the number, instead of being the other way around. Then I checked out the km to 0 indicator and it indicated 220 when the tank was at showed 50 liters were in the tank. The correct value should be approx 400.
I am certain it is using US units instead of the metric system. Is there a way I can fix this without taking it to a dealer?
Thanks
Axel
Old Aug 3, 2008 | 06:07 PM
Spike555's Avatar
Default RE: Miles and gallons instead of kilometers and liters
Check your owners manual. There is a way to change it back. Not sure how though. I belive that it involves pressing the two buttons on the side of the display, the time set buttons.
Old Aug 4, 2008 | 06:30 PM
Press and hold the hour and minutes buttons till it flashes and switches over. I believe thats how it is done.
Old Aug 29, 2008 | 05:30 AM
axelm's Avatar
I just got my car back from the body shop and the trip computer is back in kilometers. Go figure!
The clock was not right so I guess somebody jump started the car or they played with the hour and minute buttons.
PinnacleWax
Dec 9, 2013 11:55 AM
kapka42
Jan 31, 2011 10:06 AM
miwachiru123
Nov 9, 2010 09:46 PM
rbartl
Jan 11, 2009 10:26 PM
monitors
Jan 22, 2008 01:57 PM
