mini mystery
Old Aug 22, 2007 | 09:28 PM
strike14's Avatar
Default mini mystery
Okay have a 95 volvo. Now at first runs fine but, after say 30 -40 mins of running I get an occasional rumble. Honestly can't figure out what that can be. I was thinking it was my transmission fluid being low or maybe oil low but, anyone ever had this probelm?
Old Aug 23, 2007 | 11:25 AM
JPN's Avatar
JPN
Default RE: mini mystery
Hello Strike14,
Welcome to the forum, I hope you find it helpful & enjoyable.
I myself have never had the kind of problem you have described. Does it always occur after 30-40min. of driving? With limited info, I can only suggest that you check the proper fluid levels & conditions (engine oil & transmission fluid, and coolant). If you could be more specific as to the rumble, we may be able to help you better.
Sorry I couldn't help you any better at the moment.
JPN
Old Aug 23, 2007 | 09:58 PM
phoenix_iii's Avatar
Need more info. Rumble? Where does it sound like it's coming from? Do you feel it in the steering wheel? Do you feel a loss, or surge of power? Anything in the pedals? Speeds when experienced? Frequency? Recent maintenance/neglected maintenance?
Old Aug 27, 2007 | 04:16 PM
strike14's Avatar
I checked my fluids. Put some more transmission fluid and oil was fine. Still heard the rumble. It feels like it's coming from the bottom of the car. Latest maintenance was replacing brake pad which are semi metallic and putting in a new radiator.
Old Aug 27, 2007 | 07:46 PM
1996850turbo's Avatar
If you did not use Volvo pads it is most likely your rear brakes. There is a shim kit available at the dealer for like $15 to help aleviate this rumble.
Old Aug 30, 2007 | 10:46 PM
strike14's Avatar
oh okay thanks man appreciate it.
MC92
Feb 22, 2010 12:52 AM
stickydub
Jul 8, 2008 12:33 AM
bobkeenan
Sep 28, 2007 08:22 PM
S60D5
Nov 27, 2006 11:21 AM
crazynlazycolombian
Sep 27, 2006 04:18 PM
