motor cuts out at 2,000 rpm
Old Feb 8, 2012 | 05:41 PM
Airish's Avatar
Default motor cuts out at 2,000 rpm
97 glt. so ive been having this problem with my car that it wont go over 2,000 rpm... its really becoming a problem. it only does it when the motor is in a driving gear, not neutral or park. it also makes a "wooshing" noise when it cuts out, and has an odd noise coming from the center console when you let off the gas and at idle... i know this is kinda vauge but im hoping it is enough to get a general idea. it seems to only do it when its cold and wet also, it didnt do it during summer, just when it started getting cold and wet. i know it needs new spark plugs but would that really cause it to cut out so bad? any ideas would be appreciated, thanks
Old Feb 8, 2012 | 06:25 PM
matt01's Avatar
spark plugs couldnt hurt.
start with a visual inspection of the throttle cable under the hood, make sure nothing is in the way.
Besides that does it start well, when you give it gas, it just goes up to 2000 RPM then shifts, or it stops there and won't go up anymore
Old Feb 8, 2012 | 06:29 PM
Sounds like your intake hose or some other turbo tube is failing on you.
Old Feb 8, 2012 | 06:54 PM
matt01's Avatar
ya if it is a turbo model, could be also an intercooler piping
Old Feb 9, 2012 | 11:23 PM
Originally Posted by Airish
97 glt.
What engine do you have in it
Old Feb 10, 2012 | 10:03 AM
matt01's Avatar
its supposed to be a 2.4 LPT
Old Feb 10, 2012 | 10:46 AM
I hear an echo... Hello, hello, hello, hello, hello. You there? You there? You there? You there? You there?
I think Elvis has left the building. LOL
Old Feb 10, 2012 | 11:10 AM
Airish's Avatar
sorry guys ive been busy and havent been able to write back, it is an inline 5 turbo, it goes up to 2,000 then feels like it cuts the fuel or something, i dont think its the trans because you can still drive it and it will shift fine, just cant floor it or even try to accelerate fast or it cuts off, i can drive around at 40 all day but if i try and take off to quick it just goes to 2-3k and spudders and bogs down.
Old Feb 10, 2012 | 11:23 AM
Hey, he's back.
So what have you done to try to fix it?
MyCorvette
Sep 2, 2014 09:37 AM
zpmada
Oct 17, 2012 11:27 AM
trailfan
Sep 1, 2009 02:27 PM
yellowtr6
Apr 27, 2005 01:36 AM
