My 850 needs the turbo replaced
Ok so I brought my car into the shop today to find out I need a new dimmer, and a new turbo (the current one is leaking oil) the mechanic said that it would cost me 1500 with out labor for the turbo.
I was thinking, if i need the turbo replaced, could I just buy a better turbo and have that one installed? Would this work? Someone told me that installing a turbo on a regular N/A engine messes up the transmission. But since my car is already a turbo would the transmission be able to handle a better turbo?
Also is 1500 too much for the turbo to be replaced?
RE: My 850 needs the turbo replaced
You may have a different seal leaking. If the turbo is still working fine I would leave it alone.
There is an oil return line that goes from the turbo to the engine block. The seal at the block is known to go bad. That might be leaking.
I would clean it up good and take it for a drive and see what it looks like.
