problems starting. could be electrical problem
Old Dec 28, 2008 | 08:29 PM
jackbrady's Avatar
Default problems starting. could be electrical problem
i have a 1994 volvo 850. a couple days ago i was driving, and i felt the car start to sputter. the RPMs started to fluctuate, and then it eventually stalled out. at first i thought it was the fuel pump. it seemed to be burning gas too rich at first. then i pulled the spark plugs out, cleaned them off, then tested them to see i was getting a spark or not. no spark from there, so i checked the distributer, that was also fine, but no spark. same went for the ignition coil. im running out of ideas at the moment. any input would help quite a bit.
Old Dec 28, 2008 | 09:59 PM
Default RE: problems starting. could be electrical problem
Check the Cam sensor. The plugs tend to fall apart.
Old Dec 28, 2008 | 10:35 PM
Psaboic's Avatar
Also check the voltage at the primary side of the coil if you are not getting any spark. If you have voltage going into the coil and still no spark, you have a bad coil
Old Dec 29, 2008 | 01:52 AM
jackbrady's Avatar
alright, cool. thanks a lot guys. i figured after we checked the ohms on the coil that it wasnt bad, but i guess it was. lame.
Old Dec 29, 2008 | 08:19 AM
Psaboic's Avatar
Well, coils don't go bad nearly as often as they used to, but if you have good voltage going in and no spark out you most likely have a bad coil. I hope it turns out to be a simple fix
Old Dec 29, 2008 | 10:15 AM
jackbrady's Avatar
yeah, me too. the thing that puzzles me is that after it broke, i went to autozone and asked them, and the guy there looked up the information about testing the ohms on the coil, and i checked it, and it seemed to be okay, so thats whats really got me confused right now, but i guess il try replacing the coil
Old Dec 29, 2008 | 07:02 PM
jackbrady's Avatar
i replaced the coil and unfortunately its still not starting. still no spark. anyone got any other ideas?
Old Dec 29, 2008 | 08:20 PM
ORIGINAL: tech
Old Dec 29, 2008 | 08:22 PM
jackbrady's Avatar
how would i go about replacing that? im not really all that good with cars
Old Dec 29, 2008 | 08:32 PM
The Cam sensor is on the back of the cylinder head on the exhaust cam. If it is OEM it looks like a black cap over an aluminum part.
There is 2 torxes screws that hold it onto the head. But locate it first then follow the wire over to like under the Dist. cap and see if the plug fell apart and the wires slide out.
The cam sensor controls spark and the injector pulse.
Old Dec 29, 2008 | 08:33 PM
jackbrady's Avatar
okay, so its under the dist cap?
about how much does one of these cost?
Old Dec 29, 2008 | 08:39 PM
Its not under the cap. The plug for it us under the cap. The sensor itself is on the back of the other cam in the same spot as like the dist.
http://www.fcpgroton.com/product-exe...ategory_id/111
That is a cam sensor you should be able to find cheaper though.
Old Dec 29, 2008 | 08:40 PM
jackbrady's Avatar
thanks a lot man
i really appreciate the help
Old Dec 29, 2008 | 09:52 PM
No problem anytime.
Vezelma
Dec 25, 2014 08:31 PM
slimflex2
Mar 15, 2013 04:24 AM
jccouger
Aug 15, 2010 03:06 AM
mjwaterma
Feb 9, 2010 12:00 AM
Keith Tobberman
Dec 3, 2008 04:21 AM
