My '97 850 Wagon seems to steer itself
Old Sep 30, 2009 | 07:04 PM
jrmcgove's Avatar
Default My '97 850 Wagon seems to steer itself
I have a '97 850 wagon and it swerves around on the road. Probably looks like I'm drunk when I'm driving. I know the rear struts are bad, but could that cause a swerving problem? I have checked out the front end and everything seems tight. I don't think it is an issue caused by the back end bouncing up and down because it does it on smooth road. Any ideas? Thanks.
Old Sep 30, 2009 | 07:23 PM
Does the car have a rear sway bar?
Old Sep 30, 2009 | 08:08 PM
jrmcgove's Avatar
I don't think so. There is a bar the goes from one side to the other in front of the rear axle, but it looks like it is mounted solid on one end and mounted in a rubber bushing on the other end. Doesn't look like any sway bar I've ever seen.
Old Sep 30, 2009 | 08:20 PM
It might be a sway bar. The 850 ones very very different.
Old Sep 30, 2009 | 08:50 PM
JPN's Avatar
JPN
It is part of VSSS function; Volvo Self-Steering System.....
I would have the rear shocks done anyway soon. Are they ordinary shocks or are they self-levelers (Nivomat)?
I would also check the basics (tyres for uneven wear/out-of-round) and have all fours aligned by laser-aligner.
The rear axles on sedans have triangular lower control arm and as Tech says Volvo often uses unique system set-up (not sure if wagons have the exact same set-up). I guess it is part of being Swedish
JPN
Old Sep 30, 2009 | 08:58 PM
jrmcgove's Avatar
So do you think the problem could be with that bar? I thought sway bars were mainly for cornering and don't really affect driveability. People take them off of vehicles for offroading to get more "flex".
Old Sep 30, 2009 | 10:06 PM
Clavius's Avatar
They also help somewhat with keeping you straight. I had my rear broken on my Rx-8 and I kept on floating left and right on the highway at times ever so slowly.
I'd check your alignment when was the last time you had one?
Old Oct 1, 2009 | 03:40 AM
JPN's Avatar
JPN
Don't forget to check tyre pressure, loose/worn/missing hardware (nuts & bolts, bushings, etc...) on suspension components.
JPN
peterjax
May 2, 2010 07:50 PM
wendy
Apr 18, 2009 09:25 PM
ICE
Apr 16, 2009 07:38 PM
iamnickcarter
Oct 8, 2007 10:06 PM
knight rider
Jun 1, 2005 01:09 AM
