My exhaust smells lilke rotten eggs
Old Dec 19, 2008 | 05:06 AM
Dainos's Avatar
Default My exhaust smells lilke rotten eggs
Does this mean anything? I know gas has sulphur in it but I was just wondering if it could be an indicator of something serious
Old Dec 19, 2008 | 06:38 AM
JPN's Avatar
JPN
Default RE: My exhaust smells lilke rotten eggs
That is a classic sign of failing catalytic converter. Have it checked but I believe you would have to replace it.
TURBO:
http://www.fcpgroton.com/category-ex...137/by_year/45
NON-TURBO:
http://www.fcpgroton.com/category-ex...136/by_year/45
They are quite expensive so you may want to look for a used cat.
Before spending a hefty price on a new/used cat, inspect the exhaust for leaks, between the exhaust manifold & the cat.
Often, the cat gets damaged by being fed with raw fuel. Some people rev up the engine right before shutting it down (why they do this is beyond my knowledge), which is one of the worst things one can do to the cat.
JPN
Old Dec 19, 2008 | 07:13 AM
S70driver's Avatar
ORIGINAL: JPN
TURBO:
NON-TURBO:
JPN
Sounds like the CAT.
Old Dec 19, 2008 | 08:18 AM
Could also be a bad O2 sensor or stuck open injectors making the car run way to rich causing the smell as well.
Old Dec 19, 2008 | 08:32 AM
Psaboic's Avatar
Most likely the CAT or the O2 sensors as mentioned. Any check engine light or codes??
Old Dec 19, 2008 | 01:10 PM
Dainos's Avatar
No check engine light on.However, i'm hearing a noise similar to when there isn't oil in the lifters
Old Dec 20, 2008 | 08:02 AM
JPN's Avatar
JPN
Some faulty cats are known to make rattling noise.
JPN
_val
Jul 30, 2013 04:03 AM
ug3t3t
Oct 4, 2011 10:18 PM
JAMML
Oct 7, 2010 10:01 AM
armeca
Apr 6, 2010 11:05 PM
joegolden
Dec 23, 2008 06:20 PM
