Mysterious Squeal/grinding noise
Old Aug 21, 2014 | 09:05 PM
Chrispy_T's Avatar
Default Mysterious Squeal/grinding noise
So I have developed a noise in the left front wheel that almost sounds like a dust shield but I have bent that back a little already so that definitely isn't the issue. It only happens in a left turn, regardless of speed. There is also a slight noise, almost a grind but more like a whir, that's audible between 10 and 25 mph. I checked the bearing and it doesn't seem like that's the issue. The car doesn't pull and the wheel spins freely on stands. I know both my axles are bad but that isn't the issue either. I'm at a loss.
Old Aug 22, 2014 | 07:15 AM
firebirdparts's Avatar
I have not experienced a bad unitized wheel bearing on a volvo, but on other cars, I have always found that they get noisy long before you can detect any sloppiness. I would diagnose that as a noisy wheel bearing based on your description.
Old Aug 22, 2014 | 10:49 AM
Chrispy_T's Avatar
That's what I was afraid of. I want a second opinion because they aren't exactly the cheapest thing to replace. I'm looking at another $250 to replace the bearings and axles(since I'm already in there.)
Old Aug 22, 2014 | 11:10 AM
Why so much? You can get an OEM bearing for $100 and rebuild the axles for $20 each if they are not toast.
Old Aug 22, 2014 | 01:27 PM
boxpin's Avatar
Totally sounds like a wheel bearing....you cannot check them they are sealed and can feel fine when you turn them. It will be a grinding whirling noise. What your describing is just that.
Old Aug 22, 2014 | 02:25 PM
Chrispy_T's Avatar
The axles are done. No rebuilding them, or I would.
volvorecycle
Oct 10, 2013 04:30 PM
abiets20
Jun 22, 2013 03:09 PM
VolvoFriend
Oct 24, 2012 06:41 PM
XC90fan
Nov 14, 2011 11:50 AM
volvovera
Jan 12, 2011 01:37 PM
