Need help asap finding timing mark
Old Jun 2, 2009 | 01:57 PM
dlaxdal's Avatar
Default Need help asap finding timing mark
I have my 1995 850 turbo apart and cannot find the timing mark on the crankshaft. I am near the point but I am not sure it is exact. Does anyone have a good picture of it. Need help as I have replaced tensioner and hydralic pulley also..
Old Jun 2, 2009 | 02:07 PM
dlaxdal's Avatar
Default what if you cannot find mark
what if you cannot find mark? other suggestions.
Old Jun 2, 2009 | 02:22 PM
850tony's Avatar
Old Jun 2, 2009 | 02:36 PM
bestharry's Avatar
this mark on the valley of teeth is also referenced from a flat area with a dimple on it just on the outer side of this gear where it meets the belt drive pulley.
Old Jun 2, 2009 | 04:03 PM
dlaxdal's Avatar
I think I found it, patience. Should the engine rotate twice freely with no binding?>
Old Jun 2, 2009 | 07:47 PM
Yes it should.
Old Jun 3, 2009 | 09:18 AM
dlaxdal's Avatar
Default Got er done
Found the mark with patience and installed the tensioner and pulleys. The belt was a little tricky keeping the right side tight.
The directions on the forum are great. I left the crankshaft on and had little problems getting belt off and on.
I must say there is not alot of room to work as the hex key to remove the tensioner pulley is very tight.
Thanks to everyone that replied to my posts.
I have done brake rotors and pads and now just tackled timing belt. Wonder what the next project will be?
Thx again
Old Jun 3, 2009 | 07:01 PM
Glad all is good.
s40dad
Jun 14, 2013 10:34 AM
Racer_S
Jul 9, 2010 02:08 PM
Sanel30
Feb 18, 2010 09:16 PM
Svtfiveoh
Apr 15, 2008 06:51 PM
whm26
Nov 28, 2007 05:47 PM
