need help fast
Old Jan 13, 2010 | 05:23 PM
dmurphy68's Avatar
Exclamation need help fast
I have had a problem for the past few weeks with my engine reving up and stay at 3 or 3.5 k . all I can do is wait for it to stop and then it is fine. well today it happened again so I pulled over because it did not go down. Now it will not start so I tried and tried finnaly it did but real rough idle now and if I rev it up it sticks at 3 to 4 k. It has been real cold here I have read all about the relay but no one says anything about the high rev. any Ideas would be appricated
thanks
Darren
Old Jan 13, 2010 | 09:37 PM
TIPSP's Avatar
Got Boost?
Any check engine light? Codes?
unplug the MAF then try starting/running the car.
Wait for the experts to get on...
Old Jan 14, 2010 | 01:21 AM
boxpin's Avatar
Sounds like your air bypass valve is sticking or faulty.
Old Jan 14, 2010 | 04:50 AM
dmurphy68's Avatar
No codes, no check engine light... (air bypass valve) are you talking about my waste gate for the turbo? and thanks for the replies so far
Old Jan 14, 2010 | 02:39 PM
supernicguy's Avatar
check where your throttle cable connects to the firewall, mine broke and caused something of this sort till i got it fixed. its just a plastic piece holding the cable to the firewall.
Old Jan 14, 2010 | 08:23 PM
boxpin's Avatar
When you close your throttle there is a valve right next to the throttle body, like a minature soda can with hoses coming out of each side. This allows air to bypass the throttle body so your engine does not die when you let off the throttle and it controls your idle. When the engine is cold it lets air by, sort of like an intake leak that makes the engine rev a little higher then calm down. Sounds like its not working right.
Old Jan 15, 2010 | 06:30 AM
dmurphy68's Avatar
Thanks to all that replied I got it running yesterday. I cleaned the throttle body and put a can of sea foam in the tank. I let it run for ten min and then drove it hard for ten min. It ran great and did not have any problems drove ot to work today and it was fine. Now I am wondering what the he'll is wrong with it
tomecsi
Feb 20, 2012 06:33 PM
turbotransprob
Aug 25, 2011 07:36 PM
j70wtc
Jan 18, 2010 03:57 PM
pgm2525
Jan 14, 2010 11:19 AM
240boi
Jul 25, 2006 10:10 PM
