Need help with my Manual Climate Control
Need some help from some of the guru's on here.
Original problem: setting 1-3 on MCC wouldn't work;
Resolution: I replaced the fan resistor and fan motor.
This
New Problem: setting 4 on my MCC doesn't work. ( Setting 4 turns the fan motor off as if it were on setting 0).
Here's what I know: I replaced the fan resistor, fan relay and fan motor. Not sure what else could cause issue with setting 4.
Any help with be much appreciated. T
Thanks in advance!
This
Thanks in advance!
Thank you, The fan relay and blower resistor were used. I could test the thermal fuse with a voltmeter on the blower resistor and it is not blown compared to the old one. I do not have a workbench therefore I couldn't test the relay. I did check the front fuse panel to make sure the 30W fuse wasn't blown.
Edit: I followed this guide to install the new blower resistor.
http://volvospeed.com/vs_forum/topic...guide-850sv70/
Sounds like problem 1 was fixed by adding a functional blower resistor.
Problem 2 could be caused by:
- blown fuse 11-5 (30A); this is different fuse that's used for speeds 1-3.
- or bad A/C fan switch
- or bad fan relay; the relay is only used on high (4 setting) speed.
- or faulty wiring..
